Ring & Pinion Interchange
Old May 31, 2007 | 07:56 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Anybody know if the ring and pinion are the same between a Dana 60 and Dana 70 rearends in the 79 fords?
Old May 31, 2007 | 08:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Housings are different, ring and pinon is different, axle & spider gears are different, axle shafts are different. Almost everything is different.
Old May 31, 2007 | 08:32 PM
crazyredneckanyhow
Ok another question will a 4.10 set work in my 3.73 housing? Im takin the 70 out of the crew and want to put a 4.10 in it and slap it under the 78 so ill have a 60 front and 70 rear. figured itd be a lil stonger.
Old May 31, 2007 | 08:57 PM
taisa899's Avatar
taisa899
yup the 4.10's will work as long as they are for the same size rear.(eg any size gearing for an 8.8 rear will work in any 8.8) The housing is meant for all sizes basically
Jim
Old May 31, 2007 | 08:59 PM
crazyredneckanyhow
Ok is there anything else i need to cahnge or just the r&p? IM a bodyman and fabricator all this mechanic stuff is new.
Old May 31, 2007 | 10:40 PM
NumberDummy
All new seals, and IMO, all new bearings. Inspect the spider and axle gears for wear. And....if you've never done this before..you better use a shop manual..because you have to set the lash on the R&P. You just don't bolt everything together.
Old Jun 1, 2007 | 06:15 PM
crazyredneckanyhow
Yeah i know about the lash and stuff. I know what needs to be done lol but dont know how on alot of it. Theres a guy down the road that builds drag cars so when i do this im gonna see if he can help.
