difference between 9" gears
Old Jun 1, 2007 | 12:59 AM
Sillbeer's Avatar
Sillbeer
About 6 weeks ago the rear end in my 76 high boy shelled out. I just received the new 4:10 gears in the mail today and was comparing the 2 and noticed a couple differences. The numbers on the old pinion gear are as follows:
V Dana 2
34017 A
41 10
A3R41X
The new pinion gear reads as follows:
H Dana 1
34017
41 10
F4T28X
Also the new ring gear has clutches on either side of the gear and the old unit does not. Is the procedure for installing this the same as the old one? Thanks in advance.
-Destin
Old Jun 1, 2007 | 01:20 PM
MBBFord's Avatar
MBBFord
You've confused me.
You're saying your rear axle is a 9", but your saying your truck is a high boy, which is a F250 4x4( which would have a D60 rear).
Other than that, ring and pinon install would be all the same.
Old Jun 1, 2007 | 09:07 PM
Sillbeer's Avatar
Sillbeer
Your right. It is a D60 rear and i'm the confused one.
-Destin
