cold air intake
Old May 31, 2007 | 04:49 PM
bigbubba87's Avatar
bigbubba87
cold air intake
how would i run a cold air intake on an 87 f250 with a 6.9 so far it is stock hopefully by the end of the summer it will have a turbo and 3" duals
Old Jun 2, 2007 | 10:18 AM
PLC7.3's Avatar
PLC7.3
Check out K and N they have several new systems....... not that you should buy one just get some ideas.
Old Jun 2, 2007 | 10:25 AM
KJLYPW's Avatar
KJLYPW
Many here have fabricated up their own systems, Check out my gallery, others with pics on galleries are Dave S, Cheeperjeeper, to name few.
Old Jun 2, 2007 | 08:17 PM
bigbubba87's Avatar
bigbubba87
right now i just got bored and put two stock intakes together it had the stock one that went down and i had one that comes strait out like urs and i just put them togeather
Old Jun 2, 2007 | 08:26 PM
bigbubba87's Avatar
bigbubba87
this ain't got nothin to do with the air intake but do any of ya'll have the stock vacum cruise control that works mine will hold about 45 for a minite or so then slowely shut off it it the coffee can deal or do i have to much spring tension on the throttle?
Old Jun 3, 2007 | 06:53 AM
PLC7.3's Avatar
PLC7.3
Visit ........ http://www.members.shaw.ca/k2pilot/ for the Cruise info... could be coffee can, lines or a low vacuum from the Vpump...... any braking problems lately.
Old Jun 3, 2007 | 07:33 AM
bigbubba87's Avatar
bigbubba87
how much psi should the vacum pump be pulling no brake problems i think either i have to much tension on the throttle or its the canister
Old Jun 3, 2007 | 10:58 AM
72f2504x4390's Avatar
72f2504x4390
Check out the page PLC7.3 posted. I used it to diagnose my cruise and it was easy. I had a steering column ground issue(caused by previous owner ), two wires pulled out at the servo, and the amplifier was toast. Would have never figured it all out without that page.
My vacuum at the servo with a new vacuum pump is 25psi.
Old Jun 3, 2007 | 04:24 PM
bigbubba87's Avatar
bigbubba87
i pretty sure i dont have that much psi it will hold for a second then quit so im thinking it would be the vacum pump
