1966 - 1977 Early Broncos
fuel efficient 68-77 bronco
Old Dec 20, 1999 | 07:25 AM
Deen Hylton
Guest
Posts: n/a
Old Jan 8, 2002 | 04:04 PM
Stephen Danger's Avatar
Stephen Danger
I don't know much about vehicles but I know what I want.
But did they ever make it?
Did they ever put a 6 cylinder engine in stock 68-77 bronco?
If so... when,what,where?
If not... what is or was the most fuel efficient one?
Old Jan 8, 2002 | 08:58 PM
alpo23's Avatar
alpo23
the 170/200 small six was the base engine from '66 until '72 or'73 then it was 302 v-8 only. good luck finding one. most people want to swap to a v-8, but the little six is a good engine.
eric
Old Jan 9, 2002 | 11:30 AM
Stephen Danger
Thanks, that is reassuring!!!
Do You know if it is at all fuel efficient?
Old Jan 9, 2002 | 04:32 PM
alpo23's Avatar
alpo23
the v-8 came with 3.50:1 gears stock. the I-6 came with 4.10:1 stock. with 4:56 and otion. the v-8s get anywhere from 10-17 mpg. the six should get anywhere from 15-23 mpg. all depends on tire size/gear ratio/carb size. remember the bronco wieghs in at around 3600 lbs.
Eric
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
