Radiator id
Old May 31, 2007 | 10:45 AM
Lui's Avatar
Lui
Radiator id
Hello, I have what I believe is an Econoline radiator in my 66. I need to see if it can be identified so that I can go find me a fan shroud that will mount to it.
So far all I have is like a sticker with the following information:
MD : 438483
PWO : A01101
REF : A00A
will this help?
thank you very much
Lui
Old May 31, 2007 | 04:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
MD : 438483
PWO : A01101
REF : A00A
will this help?
thank you very much
Lui
None of these numbers relate to Ford ID numbers, so here are some measurements for 1966 radiators. On my 1965 F100, I used a 1971/76 360/390 shroud, it's a bolt on with no mods necessary. The best part is >>> it's still available from Ford: D3TZ-8146-C. FTE sponsor DIRECTFORDPARTS shows the shroud at $109.63 list; FTE member net: $77.49.
240 Radiator: width = 18 1/4 / height = 23 3/4" / core thickness = 1 1/4"
352 Radiator: width = 26 1/4" / height = 1/ 3/4" / core thickness = 1 3/4"
