locking up the transmision
Old May 30, 2007 | 08:19 PM
54blueford's Avatar
54blueford
ive got a 1994 ford f150 with the 300 and with the e40d transmission.its got 182000k on it and i wanted to get the fluid changed.so i took it to the dealer and they said they wouldnt do it.they said if we change the fluid it has a risk of locking up the tranny. is this true or should i take a chance and change it myself or let it be.
Old May 30, 2007 | 08:36 PM
Skandocious's Avatar
Skandocious
Not sure what they mean by that. They might referring to a flush, which can mess up your transmission by dislodging "comfortable" crud and grime inside your transmission, suddenly pushing it through vital components and clogging it up. Your safest bet on a high mileage truck is to do a fluid DRAIN instead of a FLUSH. Yes it will leave a couple quarts in the system (in the cooler lines, etc) but thats a drop in the ocean compared to the ~16 quarts that it takes.
-Chris
Old May 30, 2007 | 08:41 PM
54blueford's Avatar
54blueford
so how would i go about doing the drain in stead of the flush
Old May 30, 2007 | 08:53 PM
Skandocious
There are tutorials around for doing this. Basically you will remove the drain plug from the torque converter, and drain that. Then remove the bolts from one corner of the pan and tilt it so you can get as much fluid out as possible. Then drop and pan and drain the rest of the fluid. Replace filter, service pan gasket (possibly replace, should be reusable), bolt pan back up, fill with fluid. Here's the writeup that I followed:
https://www.ford-trucks.com/article/...nsmission.html
-Chris
juanbad79
23
Nov 10, 2016 04:47 PM
Truckpilot1329
2009 - 2014 F150
13
Jul 16, 2015 10:11 AM
bubbareitz
Feb 8, 2015 09:41 PM
FordLou
1997 - 2003 F150
13
Dec 10, 2014 09:36 PM
rews2
Jun 3, 2014 11:57 AM
