have no clue
Old May 30, 2007 | 06:59 PM
StarTrash's Avatar
StarTrash
have no clue
ok well my truck is having accelaration issues..if in 4 whee low it will slowly move up a hill.(my driveway).but in 2wheel high it will stop it from rolling back but not move forward....????? about 8 this morning it drove fine...so im lost...
Old May 30, 2007 | 08:33 PM
rboeding's Avatar
rboeding
I would guess that this belongs in the transmission fourm. Bad clutch? Bad Convertor? Something in the trans.
Old May 30, 2007 | 08:37 PM
Bouts21's Avatar
Bouts21
That is normal behavior, 4lo has a much higher torque number?? don't know if that's the right way to put it, but more torque in 4lo than 2 hi, same gear. I did the same thing with my truck a while back, at idle, 4lo as far as possible up a hill, made it about 100m or so, hi range, same gear, it moved maybe 3m, and then just stayed there. That's the reason when you go in lo range, you can't get anywhere near the speed as hi range.
