Sponsored by: Auxito
Difference ?
Old May 30, 2007 | 06:16 PM
SuperSnake's Avatar
SuperSnake
Difference ?
Whats the difference in a early built 97 and one built after Jan of 97?
Old May 30, 2007 | 07:17 PM
bigdaddyII's Avatar
bigdaddyII
Funny you ask, I have wondered the same thing. I was going to sell my factory radio to a member of BITOG whos aftermarket radio was stolen and was looking for a factory one to replace it. His 150 was an early model and he said it wouldnt fit, something about his truck having the old school (96?) dash.
Old May 30, 2007 | 07:18 PM
ECHAGAR's Avatar
ECHAGAR
1997 F250 Vin
Where Can A Locate The Vin's In My Tuck
Old May 30, 2007 | 08:07 PM
SuperSnake's Avatar
SuperSnake
Look in the corner of the driver side windsheild from the outside and there is a sticker right above the striker pin
Old May 30, 2007 | 08:16 PM
ECHAGAR's Avatar
ECHAGAR
1997 F250
Thanks
But The Chasis Vin, I Can't Located
Can You Tell Me Please!
Old May 30, 2007 | 08:19 PM
SuperSnake's Avatar
SuperSnake
Thanks
I have no idea I never really looked for one. Someone here will know
Old May 30, 2007 | 09:39 PM
galaxie641's Avatar
galaxie641
The only difference I know of is the head light panel, they have a more built in light with bolts where as the later ones have the same light panel as all other '98-'03 F150's and the slide clips, this only was the case for the first few months though, up until about 6 or 7/96 build date.
Plus all the recalls they had before 1/97 were of course fixed on the later builds.
Old May 30, 2007 | 09:42 PM
SuperSnake's Avatar
SuperSnake
mine was built 12/96 I had my front header panel off with only taking out the headlights and pulling a few plastic buttons out
Old May 30, 2007 | 10:08 PM
Smaug's Avatar
Smaug
The difference w/ the header panel is the pre 7/96 has a 'basket' the headlights and corner lights mount in. The basket mounts to the header panel w/ retainers very similar to the headlight retainers on the post 7/96 panel. The post 7/96 panel has the corner lights mounting directly to the panel and the retainers holding the headlights in. The only dif w/ the headlights is the post 7/96 have longer studs.
Old May 30, 2007 | 10:10 PM
SuperSnake's Avatar
SuperSnake
Ok Thanks that helps me a lot cause I was looking at lightning lenses
Old May 31, 2007 | 10:35 PM
Smaug's Avatar
Smaug
The Lightning headlights will NOT fit in the pre 7/96 header panel. The bulb is in a slightly dif location and it hits the panel. You can get a aftermarket header panel off Ebay CHEAP.
Old May 31, 2007 | 10:42 PM
SuperSnake's Avatar
SuperSnake
Thanks but my truck was Built In Dec 96. so the lightning lenses should work
gt40racing
Feb 26, 2011 02:03 PM
ckrichard
1997 - 2003 F150
Mar 4, 2005 11:24 PM
Bikeitswift
1997 - 2003 F150
Aug 27, 2004 12:11 PM
NascarNut
1997 - 2003 F150
Jul 5, 2003 09:59 AM
