Sponsored by: Auxito
Cupholder???
Old May 30, 2007 | 11:45 PM
schmidty_dog's Avatar
schmidty_dog
Cupholder???
Has anyone ever removed the cupholder from the dash in a 1997 F150? Pretty sure its the same dash all the way to 2003 also. Mine was in the extended position the other day and i knocked it hard with my knee, now it doesn't lock out on the passenger side. If I push side to side it has play, but the drivers side still locks out. Any ideas if I broke something or just popped something out of place?
Old May 31, 2007 | 06:13 PM
nascar88ford's Avatar
nascar88ford
I did that with our 1997 F-250LD and broke a tab off. I think you have to order a new assembly. Someone will chime in here....
Old May 31, 2007 | 10:45 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If I remember right, you have to take the trim piece that goes around the radio off. Then you will be able to see a couple of screws that holds the cupholder in. Open the cupholder and remove the ashtray, and I think theres another screw under there.
Im not 100% sure, as I never really paid much attention when I was replacing my heater core. I was just removing every screw in sight...hahaha!
