Ignition switch chime
Old May 30, 2007 | 04:30 PM
squaredancer's Avatar
squaredancer
Of late Ol' Faithful (that would be my 01 7.3LPSD) has decided that it would be fun (it's annoying to me) to activate the chime even though my key is not in the lock. If I wiggle the switch just so, or stand on my head and look backwards out the front window it generally stops. I close the truck, come back a few hours later and the moment I open the door, there's the chime. It's beginning to bug me. any clues would be appreciated.
Thanks
Old May 30, 2007 | 04:49 PM
John311t's Avatar
John311t
You can just delete the dumb chime, that way you will no longer need it.
Heres a link.
https://www.ford-trucks.com/forums/3...lly-quiet.html
Old May 30, 2007 | 05:16 PM
Whit350's Avatar
Whit350
I did the door dinger delete as my first "mod" and I use that term loosely. it was very easy and took only about 10 minutes and most of that was trying to get the ignition switch cylinder out. I used electrical tape over the contact in case I decide to undo it one day.
Old Aug 24, 2007 | 12:05 PM
squaredancer
Finally got 'round to it' the other day. Stupido ! Why didn't I do this a long time ago. The wire practically fell out, no need to remove the Cylinder lock. Thanks to all for your help.
