Fuel Tank
Old May 30, 2007 | 10:42 AM
F250ish's Avatar
F250ish
Fuel Tank
I have a 1979 F250 4x4 with a built 400 with all smog equipment removed. I would like to put a 38 gallon fuel tank in place of the 19 gallon unit. I have found a direct replacement made by Silla for $ 387 which includes the ECC. My question: Will a later model tank fit without the ECC options. I have found 80's models with the same demensions. The current tank hangs between the frame rails behind the rear axle. Any other suggestions would be appreciated also..
Old May 30, 2007 | 12:15 PM
bucks77ford's Avatar
bucks77ford
You should be able to get a 38 gal. replacement tank without the ECC option from FTE sponsers such as NPD, Autokrafters, BOTP, Broncograveyard, etc.
bill1wts
Aug 12, 2012 01:33 PM
bill1wts
Jul 30, 2012 09:05 PM
SeattleJoe
2009 - 2014 F150
Dec 19, 2011 07:58 AM
liberty2701
Electrical Systems/Wiring
Jun 18, 2009 06:24 AM
Rackpatrol
Feb 5, 2006 04:08 PM
