coughing sound after high boost
Old 05-30-2007, 01:31 AM
Fluid Power's Avatar
Fluid Power
Fluid Power is offline
When I let my foot off of the accelerator at high RPM/Boost, I hear a very sharp choppy coughing sound. I'm assuming that this is the turbo blow off. Am I correct in my assumption?
(Sounds nothing like my VW 1.8T blow off)
Old 05-30-2007, 02:12 AM
blackhat620's Avatar
blackhat620
blackhat620 is offline
Yes this is "turbo fart", there is no waste gate on the VGT turbo. Do you have an A/M air intake or stock?
Old 05-30-2007, 06:39 AM
Superdudey's Avatar
Superdudey
Superdudey is offline
yup, it scared me to death the first time i heard it, some dude pulled out on me on a back road and i was coming up a hill..BLOBLAHBLAHBLOBOBOB im like OMG MY NEW TRUCK WTF!!!!!!!!!!
i wish it would sound cool like the belts chirping on the dodges
Old 05-30-2007, 06:11 PM
Fluid Power
I've got an A/M AFE intake
Old 05-30-2007, 06:42 PM
blackhat620
The noise is much easier to hear with an A/M air intake. If you read the 6.0 forum you will see that A/M air intakes are not recommended for the 6.0 and they can void your engine warranty.
Old 05-30-2007, 07:09 PM
Fluid Power
Originally Posted by blackhat620
....A/M air intakes are not recommended for the 6.0 and they can void your engine warranty.
Thanks for the info. I actually had already read that. I just bought my truck (used) and it came with the AFE intake. I have no stock air box to return to.
Old 05-30-2007, 07:36 PM
blackhat620
Try a local salvage yard for the stock pieces, there are only three pieces, the Inlet hose end for the turbo and the Inlet hose end for the Radiator core/header panel. The part in the middle is the OEM Donalson filter unit.
Also try some of the online discount Ford parts dealers, several are FTE sponsers.
Here is a picture of the Inlet tube at the turbo and the Donaldson Air Filter assembly, only thing not shown is the inlet hose at the Header panel.
http://www.forddoctorsdts.com/articl...icle-06-01.php
Here is a drawing showing all three pieces
http://home.austin.rr.com/sbv1/Proce...irFilterRR.htm
Hope this helps.
Old 05-30-2007, 08:36 PM
Fluid Power
So are the filter and the filter box both part of the filter?
Old 05-30-2007, 08:52 PM
blackhat620
Yes they are. Here is a picture of the Donaldson Powercore with the white paper media, also comes with the blue synthetic media.
http://www.oilguard.com/Merchant4/me...ry_Code=racor1
Hope this helps
Old 05-30-2007, 09:10 PM
Fluid Power
Cool, that is the only piece I'm missing then.
Old 05-30-2007, 09:20 PM
blackhat620
Order it from these guys, as they are about the cheapest and it is the "Blue synthetic" media which is water resistant unlike the white cellulose.
http://www.dieselfiltersonline.com/F...n-Fa-1778.aspx
Hope this helps
Old 05-30-2007, 09:31 PM
Fluid Power
Thank-you. Awesome Deal !
Old 06-02-2007, 07:32 AM
davisenvy's Avatar
davisenvy
davisenvy is offline
My truck did this and I took it to the dealer. They told me it was the normal "Turbo Flutter Box". Soon after this my turb blew and had to have it replaced (under warrenty). My truck doesn't have the normal "Turbo Flutter Box" sound anymore.
bradshaw6243
08-05-2009 09:36 AM
TXHillCountry
03-22-2008 12:18 AM
smokin_6.0
04-02-2005 11:08 AM
davidm
04-02-2003 08:31 AM
Quick Reply: coughing sound after high boost
