CFM question on electric fan
Old May 29, 2007 | 01:53 PM
tbspks's Avatar
tbspks
I,m going to put a 400 in my 54 f-100 (just a little more then stock) that i am building, the radiator that i'm useing is a 3 core that is for a 72 f-100 and i'm looking at installing a 14 or 16 inch electric fan but how does one know how much/many CFM's is needed? I will be running a c-6 with the cooling line going thru/to the radiator. What a great forum for someone's first project. Thanks
Old May 29, 2007 | 03:45 PM
partsman01's Avatar
partsman01
http://www.flex-a-lite.com/auto/index.html
This should be a link that may help.
Old May 29, 2007 | 10:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Unless you are planning on running in deep water or drag racing a thermostatic clutch fan with shroud would be better, cheaper, and more reliable.
Old May 30, 2007 | 09:05 AM
beartracks's Avatar
beartracks
For electrics:
Use the biggest fan that will fit, or two smaller ones.
Use a shroud.
Straight blades move more air than curved but are noisier.
Old May 30, 2007 | 07:11 PM
danlee's Avatar
danlee
I have a 400 (stroked to 434) in my '53 F100. I have a 4 row radiator and a flex fan on my water pump. I also run a thermostatically operated 16" electric pusher fan in front of the radiator. Due to the location of the motor, I have not been able to find a suitable shroud for my radiator. I need the electric fan because I don't have a shroud. This setup provides ample cooling under all conditions.
FrankGRUN
65
Nov 6, 2018 09:32 AM
Justin Jones
18
Jul 24, 2017 05:20 PM
BGF100
Jul 24, 2017 04:04 AM
IHF250fireman
30
Aug 15, 2015 08:07 PM
66shortbed
Mar 8, 2010 07:53 PM
