1966 - 1977 Early Broncos
Steering problem
Old Jul 17, 2002 | 11:29 AM
VFox's Avatar
VFox
Steering problem
I have a 69 Bronco with power stearing, has 3.5 lift, new ball joints and C bushings, drop basket, a adjustable drag link. When I turn left sometimes my power steering squels and feels like I lost the power part of power steering for just a moment. When I staighten out the wheel sticks to the left pulling hard to the left until I turn to the right at which time it "pops" loose and then drive fine again.( it feels like something is catching or binding) I put a 4 inch drop pitman arm and a steering stabilizer on and it stopped this for a while but it is starting to reappear. Any suggestions as to what might be causing this? Steering box? Can I adjust drag link to take out this "periodic binding"? Any help is appreciated.
Old Jul 19, 2002 | 01:33 PM
spartamouse1's Avatar
spartamouse1
Steering problem
knock the drag link off the pitman arm and then try it. if it still does it, then you know it is the box. if it does not do it then you know to keep going. something else you might check is the axel joints. have seen the axel joints freezing up and causing something like you are describeing.
Old Jul 25, 2002 | 11:52 AM
44dwarf's Avatar
44dwarf
Steering problem
rderr
13
Aug 28, 2013 06:35 AM
5.4L to Freedom
Feb 13, 2011 03:55 PM
eagleridge5
Dec 8, 2006 08:39 PM
rowdy123
Jul 11, 2005 10:26 AM
Skoozo
May 24, 2003 08:44 PM
