1966 - 1977 Early Broncos
Brake Conversion Kits/compatability
Old Jul 19, 2002 | 01:35 PM
mork71's Avatar
mork71
Post Brake Conversion Kits/compatability
I'm looking to convert my '71 bronco's brakes to disk but don't really know where to start. I know there are kits so can anyone recommend a particular one? Also, I've heard a lot about compatable brakes from other vehicles. Any suggestions?
Thanks, Mike
Old Jul 19, 2002 | 11:21 PM
josh3972's Avatar
josh3972
[updated:LAST EDITED ON 20-Jul-02 AT 00:25 AM (EST)]assuming you have a D44 these links should help if you don't wan't to buy a kit.
http://www.alloffroad.com/issue/2000...discbrakes.htm
http://www.bronco.com/technical/upgr...nversion.shtml
or you could get a kit from Wild Horses, Duff, BC Bronco's, ETC...
Old Jul 26, 2002 | 08:20 PM
plowd1's Avatar
plowd1
Hi
I just did a brake conversion on my 74 bronco I used the knuckles out on a 78 ford dana 44 I replaced everything except for the backing plates, dust covers and spindles. Some don't tell you about replacing the ball joints but I did those as well. As it turns out I probably spent about the same as I would have to get a kit but you could aquire some of the stuff cheaper than I did. I kinda got some wrong information on it. I would stick with a ford doner although chevy Dana 44 is compatible I think its alittle less hastle
Old Jul 29, 2002 | 12:49 PM
josh3972's Avatar
josh3972
