Offroad & 4x4
Boggin Bronco
Old May 29, 2007 | 07:05 AM
95bogginbronco's Avatar
95bogginbronco
Boggin Bronco
Hey Guys,
Took the Bronco out boggin this weekend. The place was called Gibson's Hog and Bog. I faired pretty good. The only carnage was one of my dual exhaust tailpipes is hanging lower than before. It got tweaked a little bit after going over some bumps pretty rough. I think I might have gotten some air too as the one landing was pretty rough. TTB held up great, couldn't be happier with it. Bronco's sure are tough trucks. It took everything I could dish out and kept going. Then I drove it home at 70mph covered in mud. Cleaned the wheels and brakes out first though. Just so you know I run a 1995 bronco w/ 302, E40D, 3.55 gears, manual shift 1356, rear Limited slip, 31's. It only got stuck once. I found out some stuff though. I need pull points and some 33 inch mud terrains. The old,bald all terrains did just fine but I want a little more performance. I did use 4-lo and 2nd gear. Gave me more than enough power and plenty of wheel spin. Does anyone know where to get a good hitch for the rear with a D-ring shackle, front tow hook tips, and tire suggestions would be great too. I am keeping the 31's for on the street. I am only going to run the 33's in the mud when I get to the pit and change them back before I leave. So I will need rims also. I don't want to run boggers because I don't believe I have the power to turn them. Keep in mind this truck is my DD. Also used stuff is fine with me as I am a college student and have a low income. Thanks for the help guys with the tire pressure tips as that made a difference also.
Thanks,
BogginBronco95
Old May 29, 2007 | 09:49 AM
75F350's Avatar
75F350
Good job. Glad to hear you kept the carnage down to a minimum, and even happier to hear that you had a good time. Thats is what it is all about, getting, in, getting out safely, and having the desire to want to do it bigger and better when you go back.
For your rear reciever, plenty of places have them, and they run about $100.00. D-ring shackles mounts can be made / bought to just slip right into the reciever itself. I run one up front, and one in the rear. PLent strong, and the 3 1/2" shackle fits my big old six inch strap. As for the front of your rig, you could try what I did. I made hitch that I modified to fit behind the front bumper and exits from behind the front license plate. I remove the plate for off-roading and instert the shackle mount into the front reciever. Loks good, and came out clean, but it also gives me decent access up high. Really helps when everything is under the mud.
Old May 29, 2007 | 10:50 AM
95bogginbronco
Thanks 75F350 you gave alot of good info. I was pondering the thought of using a front receiver hitch as I noticed you can buy them but I found out that they won't work with the front sway bar so that won't work. I'm going to look for the easiest way to install tow hooks on the front. It doesn't need to be pretty, just functional.
Old May 29, 2007 | 04:16 PM
fmly fun's Avatar
fmly fun
you can as so put a slip in winch down the road if you go the reciever route
Old May 29, 2007 | 06:26 PM
rbloodhound's Avatar
rbloodhound
I like super swamper TSL's. I run the nylons on my 88 f150. The only tire that i have found that pulls better is a bogger. a set of 33's will run about 7 to 800 dollars. as for rims you can get a set of black steel wheels cheap or look around the bone yards. You should have no problem clearing the 33's. I ran 36's for 3 years with only a 3" body lift. Any good ride is one that you can drive home after. have fun.
95bogginbronco
Offroad & 4x4
Jul 30, 2007 03:19 PM
95bogginbronco
Offroad & 4x4
17
Jul 16, 2007 04:14 PM
95bogginbronco
Offroad & 4x4
May 26, 2007 06:50 PM
95bogginbronco
Offroad & 4x4
Jan 5, 2006 01:35 PM
95bogginbronco
1978 - 1996 Big Bronco
26
Jun 30, 2005 12:11 PM
