1966 - 1977 Early Broncos
Air Cleaner - 302 - 2brl
Old Jul 27, 2002 | 09:17 PM
badmechanic's Avatar
badmechanic
All
I have a 71 EB with a 302. It currently has the stock 2 brl carb with an air cleaner that I believe came from another vehicle. Anyway, I would like to put a K&N type filter on the car. I bought an aftermarket chrome type filter, but it wouldn't fit over the choke.
Has anyone had success with an aftermarket air cleaner? Details would be appreciated.
Thanks
-badmechanic
Old Jul 28, 2002 | 12:18 PM
Like M. Fords's Avatar
Like M. Fords
There is not much space between the carb and the hood on these early Broncos for aftermarket air cleaners, unless you have a body lift, a hood scoop, or a special aftermarket hood. That is the reason for the stock Bronco's offset air cleaner. Check you current hood clearence using clay or a ball of aluminum foil on top of the air cleaner and close the hood on it. The hieght of the crushed ball will show you your clearence. Allow at least 1/2 inch clearence for engine movement.
Old Jul 31, 2002 | 10:41 PM
Curtis360's Avatar
Curtis360
I put an Edelbrock Performer 500cfm and Performer intake on my 75' with a 1" spacer, and an Edelbrock 14" air cleaner. Just go to your local parts store and they should have a grab bag of air cleaner spacers for about 6 or 7 bucks that will work for you.
Old Sep 17, 2002 | 01:15 PM
flpanhead's Avatar
flpanhead
I got the Ford Motorsport Chrome Air cleaner and it has indentions on the bottom to clear the choke. I have been using it for about 7 years. They are about $39 and you can get them from Summit, Jegs, etc.
Old Sep 17, 2002 | 10:07 PM
69BRONCO's Avatar
69BRONCO
trepid94
Oct 11, 2014 09:40 AM
danzigs
Dec 22, 2010 04:05 AM
badmechanic
Dec 5, 2002 09:36 PM
badmechanic
Oct 21, 2002 10:55 PM
