Fuel leak and a code.
Old May 27, 2007 | 11:24 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The (hopefully) last lingering problem we're having with this ranger (1997 2.3 4x2 manual) is that when you fill the tank past 3/4 full it dumps gas on the ground. The only code I still get, after the engine change, is a P1443. According to the PDF in this forum that is an evap canister problem of some sort.
Is the evap cannister mounted close to the fuel tank? I'm planning on pulling the bed off the truck to find the fuel leak next weekend, but now I'm thinking that both problems are from the same source.
Any thoughts?
Old May 28, 2007 | 12:32 AM
Rockledge's Avatar
Rockledge
Do you know for sure that the tank isn't actually full when the overflow occurs? Are you going by the fuel gauge or...?
Old May 28, 2007 | 01:05 AM
cookie88's Avatar
cookie88
FTE Emeritus
No, I'm going by the gauge indication. Whatcha thinkin?
Old May 28, 2007 | 04:40 AM
mg_thomastx's Avatar
mg_thomastx
There is always the possibility that your fuel filler pipe has developed splits right where it clamps to the tank. My '95 ranger's pipe developed splits right where it clamped to the tank. I couldn't fill the tank past 3/4 full without dumping gas on the ground.
Mark
Old May 28, 2007 | 09:12 AM
cookie88's Avatar
cookie88
FTE Emeritus
Yep...that's kinda what I'm thinking too. I'm just hoping to kill two birds with one stone with this code.
So, how's an evap cannister work anyways?
Old May 28, 2007 | 09:26 AM
pgw85706's Avatar
pgw85706
Have you considered this thread?
https://www.ford-trucks.com/forums/1...rol-valve.html
