Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Copier!
Old May 30, 2007 | 10:57 PM
51dueller's Avatar
51dueller
Just diesel engines are big $$$.
Here's approximate cost of diesel swap:
7.3L IDI about $1500 used
ZF 42-5F $1500 rebuilt
New flywheel and clutch $1500
Engine mounts $100
Hydraulic clutch setup $250
Total cost = $4850
185 hp @ 3000 rpm
360 lb-ft @ 1600 rpm
Get about maybe 25 mpg
or 331 stroker
Stroker engine build $2000
AOD rebuild $500
Total Cost = $ 2500
279 hp @ 4500 rpm
365 hp @ 3500 rpm
Get about maybe 20-22 mpg
What do you choose?
Old May 30, 2007 | 11:21 PM
Fomoko1's Avatar
Fomoko1
Both are good in the right application, one can`t really replace the other.
In a small truck, 1/2 ton or smaller I would go with gas.
As far as a cammed shaker goes a guy I know has a far out cammed 428 in an 39-40 Hudson coupe he drives every day right from the first dry spring day till the first snow fall. It`s a wild ride but ever so neat to listen/feel to it coming up the street! It really rumbles.
Old May 30, 2007 | 11:36 PM
96sherm's Avatar
96sherm
hoho, that would be cool!!
Old May 30, 2007 | 11:57 PM
preppypyro's Avatar
preppypyro
Yeah good point Nathan. A diesel would be a way better tower/hauler engine, but a 302 would be really sweet for a rip around everyday use type engine.
Old May 31, 2007 | 12:03 AM
51dueller's Avatar
51dueller
The 302 could still pull the occasional trailer also without a problem. I think it would be sweet to put a big engine in the box and take a picture showing everyone it's still Built Mercury Tough! I might even still walk away from a S-10 at a light....
Old May 31, 2007 | 12:15 AM
preppypyro's Avatar
preppypyro
Not might, you definatly would walk away from one. And yeah, with the motor your building it will be able to pull no problem.
Old May 31, 2007 | 12:23 AM
51dueller's Avatar
51dueller
It would be sweet to drop the wide gear set in the AOD and then it would really walk away from a light but that is also additional $$$.
Old May 31, 2007 | 12:26 AM
Fomoko1's Avatar
Fomoko1
It`s only money, what`s a little extra?
Old May 31, 2007 | 01:13 PM
preppypyro's Avatar
preppypyro
Yeah when your building a project like that, whats a few extra bucks?
Old May 31, 2007 | 07:55 PM
96sherm's Avatar
96sherm
thats the idea to the restoration game isn't it. if you're going to worry about the money spent, then you shouldn't be doing it...
Old May 31, 2007 | 08:41 PM
Dustin1690's Avatar
Dustin1690
But yeah cant go overboard sherm or you could be so broke yea cant put fuel in the finished project truck or oil or something like that but sounds cool
Old May 31, 2007 | 09:53 PM
96sherm's Avatar
96sherm
very true!! there's always budget planning.
Old Jun 1, 2007 | 12:43 AM
  #28
51dueller's Avatar
51dueller
I think the wide gear set is like $750 unless you can find a used 47RW tranny to steal them from.
Old Jun 2, 2007 | 12:50 AM
  #29
Dustin1690's Avatar
Dustin1690
Yeah it dont take much it all adds up you throw some $$ here soem more $$$$ there
