Hypothetical Question
Old May 27, 2007 | 04:56 PM
ernesteugene's Avatar
ernesteugene
There's a lot of things to worry about in this world today, but your PSD not turning off isn't one of them. I'd like to hear about even one documented case where this has happened! I know it happens with mechanical diesels, and I used to have a similar problem with my old race car that ran a 14/1 CR, as I had to routinely put it in gear and pop the clutch to kill the engine. If you don't have a manual tranny, and you're really worried about this, just install the TC clutch lock up mod, and use it to kill your runaway PSD!
Old May 27, 2007 | 05:22 PM
John311t's Avatar
John311t
If the motor is running off its own oil, how would you electrionically stop it from using its own oil? There have been runaway PSD's before but they were modified a bit more than a chip. It doesnt matter how many electronics are on it, if the motor will get oil and air it will ignite. There are only two thing needed to keep a diesel running and that is air and fuel/oil.
There are cases out there of a PSD runaway.
Old May 27, 2007 | 06:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
True, but they are very few and far between. None of them that I am aware of have runaway on #2.....it's always oil.
Old May 27, 2007 | 06:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
When we dynoed the 3406B Caterpillars that we rebuilt at school, we used a guillotine style air intake to mount over the turbocharger intake to cut the engine if it did run away. Never had to use it but it was fun making it breathe through a straw-sized hole. I think all mechanical pumps have a lever on the pump that cuts the fuel off for normal shutdown. Puts the fuel racks in a no-fuel position. I could go on....
Old May 27, 2007 | 08:31 PM
MAKO314's Avatar
MAKO314
how about a plastic garbage bag over the air filter "6637 or open style"
Old May 27, 2007 | 08:37 PM
crapr6's Avatar
crapr6
Just walk away from your runaway PSD and call the fire deptment so when it blows up and starts to burn they can put out the fire and hopefully save the rest of the truck....
just kidding iam thinking chocking off the air intake supply is the only SAFE way to shut down any runaway diesel engine..
Erik
Old May 27, 2007 | 08:43 PM
Uzumati's Avatar
Uzumati
All of our Fire truck are now equipped with runaway solenoids
http://www.mckenziecorp.com/air_intake_valve.htm
About 15 years ago a pumper responded to a gas odor and when they arrived the pumper started revving uncontrollably, Luckily no one was injured the officer new what was happening and evacuated his men and residents but when the truck blew 3 houses were taken with it.
Old May 27, 2007 | 08:49 PM
crapr6's Avatar
crapr6
WOW thats unbeliveable! I guess it's true when there is "extra" fuel that a diesel will use and start to runaway. I have never seen or heard a diesel runaway, but iam sure its a scary thing to see...
Erik
Old May 27, 2007 | 09:13 PM
ernesteugene
Where in the heck is this much oil coming from anyway, this is starting to sound like the elusive perpetual motion machine! The only places I can think of are some broken injectors leaking oil from the HP oil galley in the head, or some veeery worn valve guides sucking a little oil that gets splashed around the top of the head or vapor from the CC, but it's hard to imagine enough oil coming from either of these places to keep the engine running, and it would be running like crap anyway which should be a clue that it needs some work.
In any case, the best way to stop a runaway engine, weather a diesel or a gasser, is to simply put it in gear and pop the clutch or hit your TC lock up switch. I don't think any of the air cut off techniques I've read here will work, because air will still be sucked into the intake from the CCV, unless you've got a CCV mod.
Old May 27, 2007 | 09:21 PM
Uzumati's Avatar
Uzumati
Alot of the older diesels would run off their own CCV gasses and had shutoff valves in them. For the valve to work on the powerstroke it would have to be between the turbo and CCV inlet.
Old May 27, 2007 | 09:56 PM
Smokin''s Avatar
Smokin'
Smokin
What if you have an auto, like mine, and no TC mod? What then, if you don't think the above mentioned theories would work?
Old May 27, 2007 | 10:36 PM
ernesteugene
Well if you're really worried you should install a TC lock up switch which is one of the easiest mods there is, and I think everyone with an auto should have one anyway. Check out this thread for the details https://www.ford-trucks.com/forums/615365-tc-lock-unleash-the-psd.html . As amiller just posted above, he claims your PSD can runaway on its CCV vapors, and a TC switch is an easier mod than the valve that he suggests installing. My best engineering judgment based on over 45 years experience playing around with engines is that there's a much better chance a large meteor will strike the earth and wipe out all life than there is that your PSD won't turn off when you want it to.
Old May 27, 2007 | 11:39 PM
  #28
dsldrvr's Avatar
dsldrvr
Of all the cases of runaway PSD's or any diesel I've heard of, and it is very few, all have been in a repair shop at the time. Not saying it doesn't happen elsewhere. Blow a tubo seal so that oil is getting to the intake air and viola, you have a runaway engine running on it's own engine oil. Or like was described before on a Detroit. But most cases are from an external fuel source getting in the intake. If you ever hear a true runaway, believe me you will be running away from it not towards it at all. Only once or twice have I heard of someone, generally the person already working on it, that was quick enough to shut one down by throwing a shop rag or something in front of or in the intake. Otherwise with an uncrontrolled source of fuel coming in they generally rev until the source is used up or rods and things start coming through the block.
But your original question was not about a runaway. It was simply how to stop a running truck that would not shut off with the key, and for that to happen on a normal running engine, several things would already have to be bypassed.
Old May 27, 2007 | 11:42 PM
  #29
PowerstrokeJunkie
Watch for the meteor!
Ha just kidding, i do agree, and that about sums up this hypothetical thread.
Old May 27, 2007 | 11:48 PM
  #30
Passin Thru's Avatar
Passin Thru
Mine has a mechanical cam driven, and a Hi P oil driven pump so Id just open the fuel darin on the fuel strainer 1st. After havin been around diesels for 40 yrs now I think Id be able to stop it unless it was aV8 Detroit which could run backward on engine oil and would just blow up after while.
