Clearance Issues
Old May 27, 2007 | 10:43 AM
428HIGHBOY's Avatar
428HIGHBOY
Cool Clearance Issues
Well I have my new 428 done and running !! But,,,,I have a big problem with the headers. Do to the fact that I put a high pinion d60, there is only 1/4" between the header and front driveshaft. I had to pull the driveshaft so I could drive it. I sure as hell wasnt going to let it just sit there with that new engine and not be able to drive it.
So the only solution I can come up with is a 4" suspention lift. The problem with that is about $1300.
I was wondering if anyone else has ran into this. If so, is there another header that will clear. New headers would be alot cheaper.
Old May 27, 2007 | 10:45 AM
428HIGHBOY's Avatar
428HIGHBOY
I forgot to mention that the valve cover rubs on the brake booster. Is there a smaller booster to fit on a 76?
Old May 27, 2007 | 11:12 AM
428HIGHBOY's Avatar
428HIGHBOY
I added some pics of the new engine in my gallery.
Old May 28, 2007 | 04:02 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Anyone?
I know, on my '74 highboy, I put in a '76 power booster and it cleared the valve cover without any problems. And that booster was MUCH thicker than the original, but SMALLER in diameter. Sounds like you need to go to the auto parts store and mix-and-match...
My headers came very close to the front driveshaft too, but I had a low-pinion Dana 44 front. Sorry, can't help on that one
Old May 28, 2007 | 07:29 PM
428HIGHBOY's Avatar
428HIGHBOY
So is the 76 booster going to be the smallest that will fit? If so, I may need a small body lift on top of the suspention lift. The next thing will be an extention ladder for my wife. Or just not let her ride with LOL!
Old May 28, 2007 | 08:32 PM
krewat's Avatar
krewat
No, I meant you should check to see what the OTHER '76 boosters look like
There's probably at least two different ones...
Old May 28, 2007 | 08:37 PM
428HIGHBOY's Avatar
428HIGHBOY
Do you think there would be a diff from the cars?
Purebeef
Jul 7, 2014 05:09 PM
SuperDuty93
13
Jan 6, 2014 01:23 AM
68Ford4Life
13
Feb 4, 2012 08:24 PM
Brad Brown
Jan 9, 2005 12:30 PM
Meilichios
Dec 9, 2004 03:21 PM
