Warm/hot weather idle problems
Old May 27, 2007 | 07:57 AM
ridgerider3's Avatar
ridgerider3
Unhappy Warm/hot weather idle problems
Got a problem with my 300 not wanting to idle when the outside air temp gets above 80'.
What I have is a '82 F-100 with a 300 1bbl stock except for an re-manufactured 1bbl, elec fuel pump and a aftermarket air cleaner.
If I do stop light/in town running, it will surge and almost die 3 or 4 times then cut off. If I just barely touch the throttle, it will run but I have to have the idle up around 1000 rpm. Any lower and it will just surge from 400 to 900. It also "shuts down" when I let off of the throttle while driving, but picks right up when the throttle is pushed.
When I shut the motor off, go in somewhere for less than 30 mins, it starts right up, but refuses to idle. After driving at speed for 10 to 20 mins, it will idle if I have to stop, but will soon start all over again.
The motor also runs "cold", with the temp hardly getting above 180'.
I have replaced the carb 3 or 4 times, and each carb does this when the warmer days arrive.
I am soon to go through emissions testing here in Delaware, and the idle of anything above 900 rpm will fail. Any CHEAP ideas on the problem?
I do have a 4bbl offy intake, 2 2150 carbs {filthy and rusty} and headers to put on the truck, but money is a BIG issue after the ex ran off, and the "big D" showed up
Old May 27, 2007 | 12:26 PM
IBLDBLUE's Avatar
IBLDBLUE
Sounds like a bad vacuum leak somewhere. I'd start chasing down vacuum hoses and replacing all hoses that are cracked. I had the opposite issue and my idle was up around 1300 RPM all the time. Turned out it was an intake leak where the upper and lower intake manifolds met.
The other thing that is possible is you might have a cracked head at an intake valve.
Check Timing. Bad timing will cause these buggy issues as well.
I can't remember if these had condensers in these years, but if so, tune it up and replace the condenser as well.
Good luck!
Old Jun 6, 2007 | 06:10 PM
ridgerider3
Posted new question under new thread
https://www.ford-trucks.com/forums/6...ml#post4813666
coplin
112
Nov 7, 2019 08:50 PM
ridgerider3
Jun 10, 2007 01:13 PM
mailman37166
Jan 18, 2006 05:28 PM
yardbird
Modular V8 (4.6L, 5.4L)
Sep 2, 2004 06:47 PM
ih8ford
Jul 3, 2004 09:49 PM
