Timming ?
Old May 30, 2007 | 07:34 PM
quicklook2's Avatar
quicklook2
i do not know what to say on this anymore.
Old May 30, 2007 | 07:40 PM
strokermotor91's Avatar
strokermotor91
Originally Posted by quicklook2
i am not in the mood to argue with you.
i do it the correct way, spout out, 10 degrees for stock or 12 to 14 for a little more performance and than spout back in.
i have been happy with 10 degrees and that is where i keep it.
for most people doing it by ear is just asking for trouble.
Where exactly is the "spout" located at. I cant find it.
Old May 30, 2007 | 07:43 PM
Bruce R Leech's Avatar
Bruce R Leech
it seems you dont need to pull the spout. just set it by ear and it should be good according to the experts
Old May 30, 2007 | 07:48 PM
strokermotor91
ok so where is the spout
Old May 30, 2007 | 08:25 PM
quicklook2's Avatar
quicklook2
go to this post:
https://www.ford-trucks.com/forums/6...ighlight=spout
subford has links to pics in his post.
Old May 30, 2007 | 10:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Please learn to read. Obviously you've tuned me out since my first post and missed several key things I have said since then. Since you missed it in post number 12, I'll put it in a quote box here:
Originally Posted by epncsu2006
I do agree with you folks, though, that for the average person on this board, setting it at the stock 10° is certainly the best thing to do.
quicklook, since I agree that I should not suggest to the average person here to time the engine by ear, it's only fair that you should agree that 10° is the only number worth telling people to use, sound ok? I really shouldn't let you guys ruffle my feathers, but it's borderline incompetent now.
The SPOUT connector is located near the driver side hood spring on 92-96 models, while it is near the distributor on 87-91 models.
Old May 30, 2007 | 10:05 PM
quicklook2's Avatar
quicklook2
what are you talking about?
why are your feathers ruffled?
i explained myself but you seem to want to keep going.
this is my last response to you on this.
Old May 30, 2007 | 10:11 PM
EPNCSU2006's Avatar
EPNCSU2006
Did you forget suggesting 12 to 14 degrees is "the correct way"?
I suggested timing by ear as the way I like to get it done and get flamed all over the place. You suggest an obviously incorrect setting of 12 to 14 degrees and think it's alright because others have done it "for more performance". Such a double standard.
Old May 30, 2007 | 11:13 PM
cbbass123's Avatar
cbbass123
wow...useful stuff here....i've been battling this pinging in my 1994 f150 5.0 for a long time...tried everything to fix it...i put my timing on 12 degrees about 3 years ago and it ran perfect. Now by reading here...its seems that just one degree could possible throw it off and cause pinging. Now if it still pings at 10 degrees, is it bad to drop it maybe to eight degrees? Thanx guys
Old May 31, 2007 | 08:56 AM
EPNCSU2006's Avatar
EPNCSU2006
It won't run quite as well at 8, but it should stop the pinging. I would try to avoid going below 10 if at all possible.
Old May 31, 2007 | 01:20 PM
351slug's Avatar
351slug
What is the total timing on 5.0/5.8 when base is at 10 deg. ? Is it like 36 or so ?
Old May 31, 2007 | 05:46 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't know what it is under load, but the most I saw free revving the engine was around 32-34 best I can remember. Best I recall, the 5.0 mustangs run around 40-42 total timing, just to give some comparison.
Old May 31, 2007 | 06:03 PM
  #28
351slug's Avatar
351slug
Wow I thought 38 was high on our 351 stang. Looks like mine is about 35ish. It pings/spark knocks at the higher rpms with 87 Octane. You can run the ***** of it with 93 Octane.
Old Jun 1, 2007 | 11:44 AM
  #29
94broncoxl's Avatar
94broncoxl
Wow, FWIW and to stir the pot some more I run mine at 13 BTDC and never experience any pinging on 87 octane.
Old Jun 20, 2007 | 01:31 PM
  #30
cbbass123's Avatar
cbbass123
Finally checked my timing on my 1994 5.0l truck...it was set at 12 degrees...I put it back to 10 degrees and bam! No more pinging...thats funny! Simple fix for a complicated problem...Thanx a bunch!
