'03 7.3l 4x4 w/ engine surging
Also last night for the first time the battery light came on and flashed for around 5 miles and then went off. Any help would be great. Thank You!
https://www.ford-trucks.com/forums/6...2-000-rpm.html
Check all the battery connections, including the starter solenoid and starter. Check the grounds too.
As far as the surging, mine is not specific to rpm and does not effect the driving it still runs like a bat out of hell. At idle you notice the sound in engine, I call it a surging but it is a little rpm change and it makes all the lights bright/dim which is extremely annoying and while I'm driving at night you can see the head lights bright/dim. Thank you for your help! Todd
