MAP code 22
Old May 26, 2007 | 10:02 PM
malveaux0089's Avatar
malveaux0089
MAP code 22
ok i did the key on engine off test on my 1995 f-150 5.0 and it gave me a code 22 and that is supposed to mean "MAP (vacuum) or BARO signal out of range - MAP" what does it all mean bazzle!!!!!! and i still cant find my damn PCV valve. i must be blind. i am going to feel like an idiot when someone comes over who knows what they are looking for and says "it is right there" in plain sight. does anyone have a picture so that i could see the location of the PCV valve or the MAP sensor.
Old May 30, 2007 | 08:39 AM
EPNCSU2006's Avatar
EPNCSU2006
The MAP sensor is mounted on a bracket just above the HVAC stuff on the passenger side of the firewall. The PCV valve is tucked in behind the intake manifold just about where the MAP sensor is mounted.
Old May 30, 2007 | 04:17 PM
bobcf's Avatar
bobcf
22= map or bp sensor out of range,
engine off, map/bp sensor is bad
engine running, sensor is bad, or there is a vacuum leak
Old May 30, 2007 | 09:22 PM
malveaux0089
so since i did the test with the key in the run position but the engine off and got the 22 then i need a new map or bp sensor? does it sound like the map/bp sensor if the check engine light comes on when i start the truck or having it idling but when i let off the gas and then get on it again quickly, the light goes off. also the truck does not feel like it has all of its power.
BradSmith-7.3L
Feb 16, 2016 07:12 PM
tracyclifton
Jun 13, 2015 04:42 PM
fordsd350
6.4L Power Stroke Diesel
Dec 11, 2011 05:56 PM
pjnadon
Jan 22, 2011 10:01 PM
gthbryce
Jul 11, 2010 12:47 PM
