North Carolina Chapter Join Chapter, Leader:Benztechnc
Gas.
Old 05-27-2007, 09:25 PM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
Gas.
What do you all find to be the best 87 octane gas around here? I'm running BP but I get slight pinging undel load in OD, at around 1500RPM.
Where I used to live I used Chevron and never had a problem with any of my cars.
I figure gas quality is a regional thing, right?
89 octane fixes the problem but I'd like to save some $.
My story: https://www.ford-trucks.com/forums/616367-octane.html
Old 05-27-2007, 09:33 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
autozone sells octane boost that is cat safe it's much cheaper than hightest gas and your truck will love it.
Old 05-27-2007, 09:42 PM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
Doesn't that octane boost stuff raise the octane only .1?
I'll gladly pay $3 (?) each tankful if it turns 87 into 93. (I suspect I can get by with 89 though.)
I read that too much octane can cause carbon buildup and make things worse, so I'm not sure what to do yet. I'm thinking colder plugs right now in that other thread.
Old 05-27-2007, 09:52 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
I run Shell plus in mine.If you are worried about carbon build up Shell has a additive in their gas to help prevent it.Your truck is heavier than mine so the 89 will help it.
Old 05-27-2007, 09:56 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
outlaw raises the octane about 5 or 6 #s. the higher the octane the better and more efficient the engine will run. most octane boosters also have an injector cleaning agent in them. the only bad thing is you MUST use the booster that is cat safe. you will probably pickup abou 2 or 3 mpg with this stuff also "if you drive like an adult"
Old 05-27-2007, 10:00 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
talk about carbon build up get a cooler plug and then you'll have carbon buildup. those trucks are made to run on s&#$ty gas if its pinging that bad take it in while it's under warrenty
Old 05-27-2007, 10:07 PM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
The ping is barely noticible and not very frequent. If I turn the radio up I can't hear it at all.
I'll check out that cat-safe octane boost. I don't have any cats, but I'd hate for a stray to get sick. (Just kidding!)
Do they sell bulk octane boost or only in one-use bottles?
What exact brand is the boost you use, or is it an AutoZone house brand?
The auto parts store closest to me is Advance Auto on Durant.
Old 05-27-2007, 10:10 PM
SuperSnake's Avatar
SuperSnake
Take it in to the Dealer like Ashley said that way it falls under warranty and you have a record of it
Old 05-27-2007, 10:13 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
"outlaw" makes a cat converter safe booster I think advance sales it. good luck . a spark knock is not a small problem if the engine is detonating it can cause damage.
Old 05-27-2007, 10:15 PM
SuperSnake's Avatar
SuperSnake
Yeah I have it too but I need a tune up.
Old 05-27-2007, 10:41 PM
ncfirefighter46's Avatar
ncfirefighter46
ncfirefighter46 is offline
well i know that the higher the octane the more carbon is build up in the engine. i found that out on research on a sho i redone when ford said only use 93 oct, in the cars and when i torn the motor down with less then 70,000 miles it was so carbon up it was not even funny, so doing some checking i found out the high test fuels carbon engines up fast then loe test, so i just set my timing to run low grade fuel, but with reg engines no high output motors the factory sets the timing to run on mid grade fuel 89 i think it is
Old 05-27-2007, 10:47 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
our 05 explorer says to run 87 or no higher than 89. if you're getting carbon buildup with high octane then your engine isn't running hot enough.
Old 05-28-2007, 01:45 AM
CaptGuz's Avatar
CaptGuz
CaptGuz is offline
john, were the 80's set to run 89 also? back then when it was like 80 cents a gallon you could afford 89 or 93 even ... i put 83 because i'm a poor public servant and county employee lol
just wondering... i used some carb cleaner and octane booster last FULL tank lol
Old 05-28-2007, 10:36 AM
SuperSnake's Avatar
SuperSnake
You can but you should be abl to run Regular with no problems at least I would until all repairs are done. Once you have it all done it should run a lot better with a fresh tune up.
Old 05-28-2007, 12:14 PM
ncfirefighter46
yes they was set to run 89 octane, from the factory.
Quick Reply: Gas.
