brake controlers
Old May 26, 2007 | 09:57 PM
cbslayer's Avatar
cbslayer
Talking brake controlers
im going to be installing a seven way plug on 86 f150 with 1700lb car hauler with single axel 10 in. electric brakes any suggestions on a good controler
Old May 27, 2007 | 01:47 AM
blackhat620's Avatar
blackhat620
Tekonsha "Prodigy" only way to go.
www.tekonsha.com/prodig.html
Old May 27, 2007 | 05:46 AM
grafekie's Avatar
grafekie
Certainly not the "only" way to go. There are plenty of others that are plenty good, including Voyager. I'd suggest finding one that is over $60. You can find new Uhaul controllers and similar brands for cheaper, but they don't work very well. Prodigy is nice, but there are other options. If you are spending the same amount of money, I'd go with the Prodigy.
Old May 27, 2007 | 07:06 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The best controller would be a BrakeSmart but unless you are towing all the time it would be a little pricey at $450.00. So I would go with a Prodigy thats what I use for a spare.
Denny
Old May 27, 2007 | 02:36 PM
skilife17's Avatar
skilife17
I agree, I went with one can't be happier.
Old May 27, 2007 | 04:27 PM
Steina's Avatar
Steina
CO River Rat
Car hauler with a single axle? Must be one massive axle!!! If you mean it has tandems with brakes on only one axle you might want to check to see if brakes are required on both, seeing as how Ohio requires 'em over 2000#. Another vote for the Prodigy.
Steve
Old May 27, 2007 | 08:29 PM
rob_nc's Avatar
rob_nc
The Prodigy has a $20 rebate until August something. See the Tekonsha site for a form.
Old May 27, 2007 | 09:13 PM
wiingnut's Avatar
wiingnut
The Prodigy is probably the best aftermarket controller out there. The only one I like better is the Ford Tow Command, also made by Tekonsha.
Old May 28, 2007 | 07:43 AM
rvpuller's Avatar
rvpuller
If you ever installed and used a Brakesmart I think you would change your mind on after market controllers.
Denny
Old May 28, 2007 | 08:57 AM
Steve91's Avatar
Steve91
I have a Prodigy, but based on everything I read, a Brakesmart will be next.
Old May 28, 2007 | 09:01 AM
wizzard351's Avatar
wizzard351
the controller i got will tell you the % of braking power and it has a diagnostic code for get this brake lights out bad wire or a short. when the wife gets back with my truck ill go look and see what kind it is and post back.it only cost like a 100bucks been useing it for 3 years very happy with it
Old May 28, 2007 | 09:26 AM
wiingnut's Avatar
wiingnut
I honestly never heard of Brakesmart. Is it a new product? Who makes it? I will say the Ford Tow Command hands down is AWESOME! I don't see myself without it!
Old May 28, 2007 | 11:59 AM
rvpuller's Avatar
rvpuller
Look here http://www.mrtruck.net/master.htm it's been around for a while but sold by another company at first. You will find that it works off the master cylinder by using a transducer similar to the Ford controller but its been around longer than the Ford unit.
Denny
