Sponsored by: Real Truck
help help help
Old May 26, 2007 | 09:40 PM
flat rock stroker's Avatar
flat rock stroker
help help help
Hi fellows
I still need help hooking up my aux fuel tank. I have a short bed and the hose looks to short for my diesel ket to fit.has anyone cut your fill pipe to get this in on a short bed truck. I have the 2005 f350 if that helps. thank you in advance flat rock stroker
Old May 26, 2007 | 09:47 PM
yamaguy's Avatar
yamaguy
when I did mine, I used a 6 inch piece of 3/8" steel fuel line that I bent 90* and drilled into the side of the filler neck. Then I brazed it in. I then used a flare X 1/4" ipt adpter to a barb fitting. I did not buy a install kit with all of my parts (pump, heavy duty filter, all the hoses, and wiring) I spent ~$170.
