caster camber?
Old May 26, 2007 | 09:26 PM
cbslayer's Avatar
cbslayer
caster camber?
ok I have a 86 f150 4.9l two wheel drive I just relaced upper and lower ball joints on both sides and my wheels still are leaning in at the top now my question is should i use those degree shims for the top balljoint or is it easy to change bushings ive dont them on a car before and to be honest I didnt even pay attention if my truck had bushings im assuming it does any help?
Old May 26, 2007 | 10:16 PM
Bruce R Leech's Avatar
Bruce R Leech
check your spring height and radius arm bushings before you start changing things.
Old May 26, 2007 | 10:18 PM
cbslayer's Avatar
cbslayer
ive never really had a truck before only cars so this is what i need input thank you ill check those tommorow
Old Jun 10, 2007 | 10:12 AM
cbslayer's Avatar
cbslayer
Thumbs up
Well sorry it took so long to reply but bruce your a genius i checked the springs and between the two front i could notice that one was slightly higher so i bought new springs 89 bucks also a good deal for new im told I just finished installing themand wow what a diffrence my truck looks like one of those prancing horses it sits alot higher in front almost 3 inches amazing thanks for the tips
Old Jun 10, 2007 | 03:55 PM
Bruce R Leech
Im glad it helped. I always check those things before I get ready to do a alignment. usually on ford trucks this age they need these things and most of the time when I change all the bad parts the truck is real close to specs .
Old Jun 10, 2007 | 06:34 PM
cbslayer's Avatar
cbslayer
yeah it did wonders they still tilt in a little but not like before my uncle told me that alighnment places actually bend the i beams to correct it have you ever heard of that seems kinda extreme to me
1992150custom
17
Mar 24, 2011 02:38 AM
Mitchcj
Aug 15, 2010 09:29 AM
KC8JPZ
Aerostar
13
Jun 19, 2007 02:02 PM
lgower
Sep 13, 2005 08:24 PM
