big problem
Old May 31, 2007 | 10:23 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
One of the four bolts behind the compressor wheel backed out and wedged against the compressor? Wow, check to see how many aluminum shavings is in the rest of the system. That's why you should use blue loctite on those bolts!
Old Jun 1, 2007 | 07:40 AM
cwall4x4's Avatar
cwall4x4
Originally Posted by Benny2002
Hey man, i live in bradenton and work in sarasota most of the time, if you need help with anything or some input, let me know
deffinetly I appreciate the offer. ill save your name so if i have an issue i can get hold of you.
Old Jun 1, 2007 | 07:42 AM
cwall4x4's Avatar
cwall4x4
Originally Posted by Izzy351
6637 is only ~$40 and is usually free to install. Since you have an early 99, you'll have to buy some clamps and procure some type of adapter to fit the filter. Some here have done it with PVC, but I don't know exactly which pieces you might need. It's pretty easy, though...
Joe
what is 6637 a air filter? please explain.
Old Jun 1, 2007 | 07:59 AM
Kwikkordead's Avatar
Kwikkordead
Read this:
https://www.ford-trucks.com/forums/2...-my-truck.html
