Engineer's Nightmare
Old May 27, 2007 | 01:29 AM
Ford_Six's Avatar
Ford_Six
Not a whole lot, really. The train the film was shot from was going a bit quick through an approach block (yellow over red signals), and the other one overshot it's stop, although the first should have only been doing 15-25 depending on the line-
Old May 27, 2007 | 10:26 AM
Frankenbiker's Avatar
Frankenbiker
There was a staged two locomotive head on back in the 1890's. It was filmed by Edison. One of Scott Joplin's first Ragtime tunes was named for the event = "The Great Crush Collision."
You can read about this crash here:
http://www.texasescapes.com/TexasRai...h-at-Crush.htm
It was just south of the town of West, Texas.
-blaine
Old May 27, 2007 | 10:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks for the link..interesting.
Scott Joplin's "Great Crush Collision" is available on a CD with some of his other Rags. The pianist is Joshua Rifkin.
There's a sheet music book available with everything Joplin composed except his Ragtime Opera "Treemonisha."
In 1938, Paramount Studios bought the recently defunct Virginia & Truckee RR. Cecil B. DeMille used the engines and rolling stock in his 1939 film: Union Pacific. There were several deliberate wrecks.
Not to be outdone, MGM bought another Nevada based line, the recently defunct Tidewater & Tonopah RR. What they used this for, dunno.
Some of the engines and rolling stock were later purchased by Walt Disney and Walter Knott.
Old May 27, 2007 | 10:52 PM
Nitramjr's Avatar
Nitramjr
I think the fault would probably be 100% the fault of the train that went past the clear point for that turnout.
How do you know the moving train was going too fast without knowing the line speed for the track and the number (angle) of the turnout? I couldn't tell from the video what number the frog was but there are some high speed turnouts that would allow a freight train to take the diverging move at 30-40 mph.
It's also tough to tell from the video if the replay is in realtime or if it is accelerated.
One thing for sure, it must suck coming around a curve to see headlights like that.....
Old May 27, 2007 | 11:59 PM
Ford_Six's Avatar
Ford_Six
Depending on the road, a train in an approach block is limited to ~25mph. That was about 45. I'm not saying the other engineer wasn't at fault, and the wreck was probably a lot less than it would have been had the train been going slower (direct head on).
Old May 28, 2007 | 07:40 AM
Nitramjr's Avatar
Nitramjr
Not trying to beat a dead horse or anything bt the video was edited (there are breaks in it) so it is impossible to say what the last signal before the crash showed.
Either way, it was lots of damage all because the stopped train went an extra 2 or 3 feet.
Old May 28, 2007 | 11:22 AM
BEECHBM69's Avatar
BEECHBM69
Actually from what I was told, the train that ran the red (southbound) was going 22 at the point of impact and the other (northbound) was going 38. The engineer on the northbound had it in run 8 trying to beat it instead of big holing it and bailing off. That would be a hard call to make.
Dan
Old May 28, 2007 | 12:42 PM
Ford_Six's Avatar
Ford_Six
Right before the train went over the crossing, about 5seconds into the film, there is a signal- yellow over red. Now again, different roads, different rules, but that generally is an approach signal.
sglaine
Dec 27, 2008 09:57 PM
jake00
19
Feb 21, 2008 08:30 AM
JohnAW
22
Jan 9, 2007 08:44 AM
furball69
18
Aug 31, 2006 06:00 PM
black wolf
29
Mar 12, 2003 07:20 AM
