Are all 390s the same?
Old May 26, 2007 | 03:41 PM
grandads76's Avatar
grandads76
I've been looking at what I would like to do when I rebuild my 390 and I'm curious if aftermarket parts like aluminum valve covers and oil pans will work on any 390. I know that some came in Mustangs and other cars and so far I dont have a clue what mine came out of. So I guess my question is that if I see something listed for a 390, will it work in my truck's engine regardless of what it originally came in?
Does that make sense?
Shane
Old May 26, 2007 | 05:33 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Oil pans and headers would be application specific sometimes. Like Truck vs Mustang etc...
Valve covers will interchange as far as bolt pattern. Things like some of the roller rocker systems out there need a taller cover or the inner baffle removed in a stock cover for clearance sometimes. The main thing you want to watch is the head vs intake matchup on the ports. Also on the heads the bolt pattern used for the exhaust mani's/headers is different on say a Mustang compared to a truck. There are quite a few differences in heads as to applications, chamber size, valve size. Same with intakes. With low riser, medium riser, high riser, GT style, C8/D2, tunnelport and SOHC heads and intakes for the FE....you need to watch and be aware of the differences and what can interchange effectively. Things like waterpumps, fuel pumps, timing covers, gaskets and oil filter adapters all have small differences also. So it's best to ask Q's as to your intended use and fitment of different parts if your not certain of what your buying. We have all spent each others money here so everyone is really good at that. But all kidding aside the guys here are great with info and what everyone has tried and used. Good and bad.
G.
Old May 26, 2007 | 05:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/64 390's (and 1962/64 406/427) have rounded valve covers without oil caps. On these engines (352's = 1958/64 is the same setup ) there's a separate oil filler pipe and cap.
Three different FE 332/352/390 waterpumps: 1958/63; 1964 (stud for generator is different from 59/63), and....
....1965/76: D4TZ-8501-A (replaces D0AZ-8501-D)...fits everything: 352/360/390/410/427/428/428CJ
Old May 26, 2007 | 06:55 PM
grandads76's Avatar
grandads76
Ok, thanks. I'm going to try and get down in there and finally figure out what this 390 came from to make this stuff easier. I just saw some nifty valve covers online and wondered if they would work. About oil pans, did I read on a thread here its better to get a rear sump for the F100s?
Thanks!
Shane
Old May 28, 2007 | 05:02 AM
f700's Avatar
f700
numbers
hi numberdummy thank you 4 the last post , i have a 330ft / bore out to 361 1967 so now i no what water pump fits got to love the numbers
Old May 28, 2007 | 06:09 AM
NumberDummy
WHOA..you don't have an FE engine in a F700..you have an FT engine (unless it was swapped)...it may not use the same waterpump!!
Give me a couple of minutes...I'll see what pump a FT engine uses.
Old May 28, 2007 | 06:17 AM
NumberDummy
A 330 Light or medium duty FT engine uses the same water pump an FE does, but otherwise...there are SEVEN other pumps listed for 330 H/D, 361 and 391 FT engines.
Old May 28, 2007 | 06:25 AM
f700's Avatar
f700
330ft hd
hi its a 330ft bore out to a 361ft i just the old one dun up but its a c6me.a block
Old May 28, 2007 | 06:27 AM
NumberDummy
You are as safe as a roo in a zoo..a C6ME block is an FE engine.
Old May 28, 2007 | 07:11 AM
f700's Avatar
f700
c6me.a
i was very lucky , i found this motor in a 59 f600 i looked at the numbers thinking to my self i have see them b4 but with mustang , he want a $1000 au for it with a clark 5 speed ,bellhousing , fully dress motor but it was only a 330ft , that what he said , i said $800 au cash , he said ok its yours , its bore out now and rebuild the lot new or made just not fited in my 1963 f 700 ,i can,t wait but the old 292 y block is deep in my heart as a great motor + it been going great for 7 year for me , when i found the old truck in a paddock it had for pistons turn one way and four turn opps made me i no y it was it the paddock now it live in a shed now works daily for 7 years , you got to love the old fordss can,t kill them , thank with the water pumps roo in a zoo they are ever where over here
Old May 28, 2007 | 07:33 AM
NumberDummy
A paddock is where horses are keep..in Oz, NZ, US...everywhere.
But in the US, the only roo's are in zoo's. No need to "tie me kangaroo down sport, tie me kangaroo down." Cuz there ain't no kangaroos runnin' loose to tie down.
(tie me kangaroo down... was a rock n roll tune from the 1960's)
Old May 28, 2007 | 08:53 AM
f700's Avatar
f700
390
i no who singer that , im a 60 model to roo are like ants over here there ever where , im near canberra i breed galloway s cows for show s and breeding
772504x4
Apr 3, 2015 07:04 PM
mustang81
Feb 2, 2013 10:01 PM
66crawler
Sep 2, 2010 04:01 PM
The R2
Feb 26, 2008 01:08 PM
Charles-65F350
19
Sep 16, 2001 09:06 PM
