JAGUAR IFS/IRS question
Old May 26, 2007 | 01:06 PM
gjermund12's Avatar
gjermund12
Can i use IFS/IRS from this jaguar it is a V12 1988 model?
Old May 26, 2007 | 03:25 PM
49fordpickumup's Avatar
49fordpickumup
1988 jag
From what I have read only series three XJ6 jag's will fit. Series three ended in 1986. Since it's only what I have read, I would measure every angle, etc. to confirm a yes or no, since I see you have the jag. Run a search at the top of the page or look through past threads as there are many threads on this subject. Lets us know what you find. Have a great day,chuck
Old May 26, 2007 | 03:49 PM
gjermund12's Avatar
gjermund12
The pic is from an ad. So i do not have the parts yet, but they are hard to come by here in Norway, and he does not want much for the parts..
Old May 28, 2007 | 10:00 PM
texan2004's Avatar
texan2004
My guess is that yes it would work. I beliee the XJ-6 and the XJ-12 used the same IFS and IRS. The only difference was the spring stiffness which of course woulod ahve been higher on the XJ-12. As suggeted, measure it before you cut the deal. You have a 54 so your frame will be slightly wider than what the JAG IFS will accomodate but you can either nothc the truck frame or the JAG IFS to make it fit.
Old May 29, 2007 | 06:41 PM
rhopper's Avatar
rhopper
That Jag looks like a series III to me. The Xj6 I took my front end from looked like that. The next model, the xj40, was a slightly different body style, so I'd say that the 1988 year is incorrect, or they didn't switch the models at the same time in Norway. Since the Xjs V12 was available until '90 (I think) and has a series III chassis, I'd say that would be a good donor. The V12 was a heavier motor than the I6, the front springs are stiffer, and the sway bar is larger in diameter.
Old May 29, 2007 | 11:18 PM
alabbasi's Avatar
alabbasi
What a sin, save the XJ12 and tear apart an XJ6.
paul2112
Apr 12, 2014 01:13 AM
Trey_Morgan
Jan 22, 2014 04:53 PM
Ziegelsteinfaust
Sep 6, 2013 01:04 AM
gjermund12
18
Feb 11, 2007 04:54 PM
rhopper
17
Mar 26, 2006 04:14 AM
