Died and won't start
99 powerstroke died and won't start. Had problems before and replaced IDM. Ran for about 1 month. SAme thing. Replaced IDM again, also replaced cam shaft sensor, still won't start. Oil level is fine. Batteries are fine. Wiring harness was fine when I first replaced IDM. Got any ideas??
When truck last died, it did it like it was electrical, not fuel. because it was instant. It didn't struggle or slobber around. I change out IDM again, just guessing that it was the problem again. I have no scanner. I would be happy to take to a mechanic, if I knew of one in my area. Dealer is not a place to go!! Can anyone help me in western Illinois or eastern Missouri?
Need to see what kind of pressure the HPOP is buidling and how much fuel pressure is available at the bowl.
Fuel - you can plumb a gauge into the test port on the rear of the fuel bowl.
Oil (HPOP) - little more difficult, you will need gauge and lines capable of handling 3000psi. on the inboard side of the head about 3 cylinders back there is a plug in the oil galley that you can remove and attach a fitting.
I'm betting on something tied to the High Pressure Oil System - IPR, HPOP, Biased ICP sensor.
