02 13 different codes
Old May 25, 2007 | 07:28 PM
4x4k20's Avatar
4x4k20
my 02 will only start if the block heater is pluged up for a few hours... then it will not start running rite until it gets hot.it skips/ shakes/ and will not acellerate. then it runs like nothing is wrong when it is good and warmed up it starts fine when hot/. here are the 13 different codes that were read p0221/266/272/275/281/230/380/541/640/1247/1662/1670/1690/ any ideals as to where i should start trying to fix my problem??
Old May 25, 2007 | 07:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Wow......There are like five injector fault codes there. The low boost codes are probably a result of them. Then there's the glow plugs and the EBV faults........it kinda sounds like something may have chewed up the wiring harness on top of the motor.
Old May 25, 2007 | 07:50 PM
nlemerise's Avatar
nlemerise
You can check out the codes for yourself, right here:
http://guzzle.rbmicro.com/dtc.html
Old May 25, 2007 | 07:52 PM
4x4k20's Avatar
4x4k20
yes/ it may be i plan on tomorrow to remove the valve cover and see what i can find . i was going to replace the glow plugs but they checked out ok on the test
Uzumati's Avatar
Uzumati
Kinda all over.
221 is one of the switches on the throttle pedal assembly
266-281 are cylinder contribution codes for #2,4,5,7
230 Fuel Pump relay driver fail
380 Glow Plug Circuit malfunction
541 & 640 Intake Air Heater
1247 Turbo Boost Pressure Low
1662 IDM EN Circuit Failure
1670 EF Feedback Signal Not Detected
1690 Wastegate Control Valve Malfunction
Old May 25, 2007 | 08:07 PM
4x4k20's Avatar
4x4k20
i am assumeing that i have al these codes because of the one main problem i have it has to be setting all of the others . i guess i will know more tomorrow when i pull the valve covers . like i say it will not start unless i have the block heater pluged up for a while / it starts but runs real rough and will not accerlate until it gets hot i have to drive it for about 5 mins. after that it seems to run strong. very confusing to me .
Old May 25, 2007 | 08:21 PM
Uzumati's Avatar
Uzumati
I was just thinking about a common denominator between all of those but cant come up with just 1 except for chaffing in the main engine bay harness or an actual PCM issue.
Old May 26, 2007 | 10:22 AM
4x4k20's Avatar
4x4k20
i pulled the valve covers today and everything looked good
Old May 26, 2007 | 11:43 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Try checking, and I mean unplugging and looking at the PCM connector and the IDM harness. Pull them off, if OK, reconnect. May have a bad connection and get lucky. From there move to others until you hopefully find something because right now you have a shotgun blast of codes with no common denominator as previously mentioned.
Old May 28, 2007 | 09:30 PM
4x4k20's Avatar
4x4k20
it tryed that no luck i am gona try tomorrow to get a idm and replace it and hope for the best
Old Jun 2, 2007 | 12:48 PM
4x4k20's Avatar
4x4k20
i swapped out both the idm and pcm with some test ones from a freind.. it still will not start up unless the engine has some heat in it . any other ideals that i can try??
Old Jun 2, 2007 | 06:23 PM
Uzumati's Avatar
Uzumati
Did you ohm out the under valve cover harness or just visually inspect it. The 4 cylinder codes are probably going to be the reason for the no cold start but they could be anywhere from electrical to compression.
dbrojr
1983 - 2012 Ranger & B-Series
Oct 11, 2013 09:54 AM
oldsub86
1997 - 2003 F150
Jul 3, 2013 10:51 PM
Shanejet
Aug 11, 2012 03:08 PM
clipper1
Nov 16, 2005 02:16 PM
