i got a question READ!
Old May 25, 2007 | 12:30 AM
muddingmcdude's Avatar
muddingmcdude
Question i got a question READ!
How much does 1 flat of fuel raise u egt cuz im around 900 floord and if u turn the fuel squew 1 more doesnt that move ur peddle back soo u dont have to get oin it to get moving?? or what i want to have more power when im pullin stuff so im not at the floor soo if i turn it more fuel wouldnet the move the power of where ur peddle is? and im gettin bout 9-10 psi im guessin with the turbo thats wher i should keep it to be safe??
Old May 25, 2007 | 09:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There is no direct EGT to fuel screw relationship that I am aware of.
The fuel screw changes the fuel pressure inside the IP, so several other things could effect the EGT just as much as the fuel screw does.
Also the fuel screw does not move the linkage.
It has almost no effect on the idle fuel delivery.
The screw is more along the lines of a max fuel delivery screw.
The biggest difference is noticed at wide open throttle position.
Since the max fuel delivery is increased, you will notice you can run your max EGT you can now run with it floored at a lighter throttle position.
