1978 - 1996 Big Bronco
Tailgate Window-'93
Old Nov 30, 1999 | 01:42 PM
Doug Nickels
Guest
Posts: n/a
Tailgate Window-'93
My window opens and closes only from the dash, not from the key switch in the 'gate. Is this a bad switch, or?? I took the rear access panel off and found everything looking normal.
Old Dec 1, 1999 | 12:31 AM
Don's Avatar
Don
Tailgate Window-'93
common problem.......mine's been broken since i bought it, never bothered to fix it seeing i dont' open the back all that ofter, so if i do , i use the dash swith......there are actually two seperate swithes in the tailgate.....the key rocker actually operates both....one side is up, the other is down.
Old Dec 3, 1999 | 07:08 PM
Chris's Avatar
Chris
Tailgate Window-'93
Hey man ,,,ive got a 93 bronco and my tailgate window got all messed up too,,,it wound up being the switch which cost me round 20 bucks,,,i wouldnt wait till the switch totally went ,,,i did and my window got stuck in the down postition,,,i got it up by jumping the switch with a 12 volt battery,,,it was messy and a pain in the ***,,,hope it helps,,,let me know what happens ,,,,later
Old Dec 6, 1999 | 01:12 AM
rollingthunder's Avatar
rollingthunder
Tailgate Window-'93
