Sponsored by: Real Truck
Load Floor
Old May 24, 2007 | 02:01 PM
harstad23's Avatar
harstad23
Load Floor
I want to remove the Load Floor to have some more storage under my back seat. IS this possible without a lot of hassle?
Old May 24, 2007 | 04:31 PM
sofdchief's Avatar
sofdchief
load floor
Yep, it's pretty simple. I have had mine in and out 2 or 3 times. Just unbolt it, but remember that a couple of the rear seat bolts must be removed as well. It can be a little bit of a pain to get out, just because it tends to flex in the middle a bit. Works easier if you have an extra person to lift the opposite end out at the same time. Just remember when you are done to put all the bolts back in, otherwise you will have a hole in the floor that is open to the outdoors (If I remember correctly). Shouldn't take you long at all to remove it. Also, it takes a "star" type wrench, but i can't remember the size....you might want to check into that first and make sure you have the right one.
