rear end identfication
Old May 24, 2007 | 01:34 PM
betontheturtle's Avatar
betontheturtle
ok I know somebody wrote how to id the rear end on the ex but I can't find it tag says 413 B do it mean I gots a 4:10 rear ? also second ?? what is the torque for the turbo clamp to the down pipe( new 4" Ansa Silverline in 304 SS) thanks
Old May 24, 2007 | 04:58 PM
RoyC's Avatar
RoyC
If you have a PSD Excursion you have a 3:73 rear end.
RoyC
Old May 25, 2007 | 12:25 AM
1's Avatar
Still no way to tell if its a 10.25 or 10.50?
Old May 25, 2007 | 01:19 AM
betontheturtle
somebody here posted the axle code for these rearends I picked up the 08 ford diff cover at the local dealer $39.41 good deal but was noticing the tag listing a 413 B axxle code any help out there??
I know it should be 373s but now i'm not so sure
Old May 25, 2007 | 02:07 AM
1's Avatar
count the teeth when you have the cover off. Youll know FOR SURE then. Pinion teeth divided my ring gear teeth = gear ratio.
Old May 25, 2007 | 11:23 AM
betontheturtle
oh yeah! thanks, duh.
