Waterproofing your electrical
Old May 24, 2007 | 07:22 AM
Scott_McGee16's Avatar
Scott_McGee16
I am hoping to put together a list of tried and true tips/ advice for waterproofing the electrical systems of our trucks, particularly in the 4x4 department. Specifically does anyone know if a guy can buy a totally waterproof alternator? Somthing that can run submerged in muddy water?
Old May 24, 2007 | 10:57 AM
Franklin2's Avatar
Franklin2
Not sure about that. The problem is cooling. If you sealed the alternator completely, then all the heat would have to be extracted through the case to the ambient air. The way they do it now is push ambient air through the alternator to cool it.
You may want to figure out what the military does with the hummer. I saw a show where they went through water over the hood. Of course it was a diesel with a snorkel so no sparkplugs to worry about, but you would think it had an alternator(may be 24 volt though).
Old May 24, 2007 | 07:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
Low voltage electrical devices like starter motors and alternators work under fresh water. Connections should be sealed and greased with silicone dielectric compound. Eventually water will compromise connections thru corrosion tho.
Old Jul 28, 2011 | 06:02 AM
muscletruck7379's Avatar
muscletruck7379
kinda an old thread, but if it got going it would probably make a great sticky.
caddillac used a water cooled alternator, or you could have a disconnect (torque 1st, im kinda nervous about driving an alternator under water, even if it will work...)
weatherpack connectors if you cant get military grade., along with the dielectric grease
silicone the cap to the distributor, drill a vent. cover or plug when fording.
Acksd
Nov 30, 2016 03:38 PM
Wheelman55
May 25, 2016 05:12 PM
nitro3421
6.7L Power Stroke Diesel
28
Jan 2, 2015 05:54 PM
F350idiford
1978 - 1996 Big Bronco
Apr 12, 2012 03:14 PM
djmac
Nov 23, 2006 11:43 PM
