1978 - 1996 Big Bronco
mass air sensor problem
Old Jan 5, 2000 | 01:53 PM
waste n aweigh
Guest
Posts: n/a
I have a 1994 ford bronco 5.0. when ambient air temp is above 85 degrees F the truck loses a significant amout of power. there are no signs of overheating or trans problems. the computer has been checked. when temp is under 85 degrees F (approx). engine performs normally. Could this be a mass air flow sensor problem? or something else. Does anyone have any ideas
Old Jan 5, 2000 | 04:37 PM
Phillip Guidry's Avatar
Phillip Guidry
It may be the ECTS,for engine coolant temp sensor, that is giving a false or no reading to the computer. The 85 degrees is the magical point where the computer wants to start "seeing" the sensors,one by one,until it can start controlling the engine totally.Check it out before you overheat some pistons.
Phillip
Old Jan 5, 2000 | 06:22 PM
Eddie's Avatar
Eddie
Old Jan 28, 2005 | 04:00 PM
poffutt's Avatar
poffutt
This is the same problem I am having. This post is from 1999 it is now 2005. I hope you are still around. Did you find the problem???
qrguiles
Apr 22, 2025 05:46 PM
Red454sedgwick
Apr 17, 2016 09:46 PM
CaptainJack_7
Feb 23, 2016 07:53 AM
White_Pride
1997 - 2003 F150
Feb 1, 2015 07:00 AM
TexasGuy001
Feb 5, 2002 06:58 AM
