1979 400 engine leaking air
Old Jun 10, 2007 | 11:24 PM
Jermafenser's Avatar
Jermafenser
Originally Posted by Torque1st
A plugged PCV system and plugged valve cover ports will build pressure in the crankcase.
That may be it. The PCV valve is new. Someone squashed on gaskets on the valve covers...I can see it plain as day. Where are the valve cover ports?
Old Jun 11, 2007 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is a port on the top of each cover. One has the PCV valve in it connected to the base of the carb and the other has a hose to the air filter assy.
Old Jun 11, 2007 | 01:10 AM
Jermafenser
Ohh, those ports. Yes, I have both present and accounted for. Passenger side goes to the breather element in the air cleaner assembly, the other in a PCV going to the carburetor. Both were replaced recently.
DutchB100
Apr 19, 2012 10:19 AM
HardScrabble
Aug 29, 2011 10:10 PM
BOBSDIESEL
Feb 17, 2008 09:46 PM
mebe2k
Jun 23, 2006 08:25 PM
Lookinfurfun
Sep 13, 2002 11:49 PM
