Help - FE390 coolant leak from exhaust manifold bolt - Ford Truck Enthusiasts Forums
Old 04-18-2012, 10:26 PM
DutchB100's Avatar
DutchB100
DutchB100 is offline
DutchB100 is starting off with a positive reputation.
Recently I rebuilt a 1970/73 FE 390. The heads were redone by a reputable shop. The engine was broken, run 3-4 times. It hasn't been driven though. After the last time the engine was run, a slow coolant leak develop on the underside of the driver side exhaust manifold. It's possible the leak is coming from one of the lower exhaust manifold bolts. Has anyone experienced this before or has seen it?
Old 04-18-2012, 11:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
There shouldn't be any coolant reaching the exhaust manifold bolt holes unless the hole was drilled out due to a broken bolt, but drilled too deep.
I'd be inclined to think the head gasket is leaking.
Old 04-19-2012, 09:51 AM
critterf1's Avatar
critterf1
critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Head gasket. No coolant reaches the manifold bolts.
Old 04-19-2012, 10:18 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Pulling the bolt in question will tell you when coolant comes out after the bolt does
If this is the case, RTV or some other type of glue, like you'd use on water pump bolts is in need here.
What I would do if this is the case is bring the head back to the machinist who botched the job, but not sure if that's something you want to get into.
Old 04-19-2012, 10:19 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Try warming her up than re-torque the head.
73FOMO
01-31-2017 11:38 PM
wollow007
10-27-2015 02:15 PM
kr98664
10-04-2015 06:34 AM
73FOMO
02-02-2014 11:20 PM
dferg250
09-27-2012 05:14 PM
Quick Reply: Help - FE390 coolant leak from exhaust manifold bolt
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
