Cruise Control - loose stem
Old May 23, 2007 | 01:48 PM
JohnMcHugh1's Avatar
JohnMcHugh1
2000 E250, the stem where the cruise control selector meets steering column, is not a tight fit. I can wriggle it around, and hesitate to twist any
wires that I am sure are involved in this setup. How to best 'tighten' the stem connection to the steering column is the question. thanks.
Old Jun 14, 2007 | 03:46 PM
amish77's Avatar
amish77
It might not be a screw type tightening anyway. Try looking at what holds it in place. I've had a selector that was a clip fit, but I can't remember how I got it in or out.
Old Jun 14, 2007 | 04:05 PM
JohnMcHugh1
clip fit?
As you can see by the reader/response numbers, the answer to this is not popularly known, or perhaps few have the problem. I presume mine is an after-market, dealer install device, in that I have Cruise Control when it is likely my Clock Spring is faulty (no horn, airbag light blinks 32).
It seems the stem connects to a collar, or perhaps through a collar. Trying not to twist wires too much, I can twist the collar to 'tighten' it on a near unconnected 'stem', and then what... Does not seem to help tighten/attach to the steering column. I was looking to see if the 'collar' had a pin hole, for tightening, without finding one yet. Very awkward for my fat fingers to work in this area, and to 'see' much in detail.
A missing 'clip' would explain a lot, if that is the case. Thanks.
Old Jun 14, 2007 | 04:58 PM
Club Wagon's Avatar
Club Wagon
That's what I was thinking when you talked about a "stem" by which I had presumed you meant a STALK sticking out of the steering column.
To my knowledge all the '92 & up E-Series w/FORD cruise control used push buttons in the steering wheel spokes/pad to operate CC.
I suspect a variety of different systems were installed by the aftermarket, making it very difficult to help you with specifics, blindly guessing what components you have.
Old Jun 16, 2007 | 12:39 PM
amish77's Avatar
amish77
Sorry man, I'm drawing a blank as to what you have in the truck. Might have to pull stuff to make the room to see what's going on.
Old Jun 16, 2007 | 01:20 PM
pfogle's Avatar
pfogle
I know on the dealer installed units they use a stem, stalk, whatever you want to call it. On our '04 there is a hex nut on the outside but I don't know what's on the inside. I'd think that if you have a collar out you may have either a nut or a C or E clip on the inside. You won't know until you pull the plastic covers off the steering column.
Old Jun 17, 2007 | 12:38 AM
Club Wagon's Avatar
Club Wagon
Would a FORD "dealer" even consider installing any aftermarket cruise control systems on new vehicles?
I know many conversion companys install often inferior, aftermarket CC systems. Let me continue to impress upon you that there are several different systems, using different components. If its got a stalk or stem '92 & up, its aftermarket.
Old Jun 17, 2007 | 01:57 AM
pfogle's Avatar
pfogle
Yes. My father purchased an '04 in late '05. It was an ex-enterprise rent-a-van. No cruise. He asked the dealer about installing cruise before purchase, and they did. It's got an aftermarket system on it. It has the stalk sticking out of the steering column behind the multi-function switch.
Old Jun 17, 2007 | 11:16 AM
IntrepidCUB's Avatar
IntrepidCUB
i believe the dealer would do that it jsut seems that most cars come standard with cruise its not needed.
Old Jun 17, 2007 | 06:33 PM
pfogle's Avatar
pfogle
Actually I've noticed a LOT of car lately without cruise. It's easier to add now though, with the "drive by wire" systems it's just a program in the computer.
Old Jun 17, 2007 | 09:34 PM
JohnMcHugh1
How 'simple' is it to pull the plastic covers off the steering column? Snap off, snap on? Much to 'remove'? thanks.
Old Jun 17, 2007 | 10:29 PM
pfogle's Avatar
pfogle
Should be just a few screws.
Old Jun 18, 2007 | 02:37 AM
Club Wagon's Avatar
Club Wagon
To pull BOTH "plastic covers off" on my '92 Chateau was a bit of a challenge.
There are several screws, mine included one down near the right lower front corner that must have been installed by the devil, the others were easy. However, to get the right hand cover "off" you also need to remove the ignition lock cylinder, a procedure that might intimidate you, but is easy if you know the trick.
The manuals I read also told me I had to remove the steering wheel & deal w/air bag, in order to remove the dash panel. However, I was able to twist & bend the panel & remove it w/o R&R the steering wheel.
Old Jun 18, 2007 | 10:58 AM
IntrepidCUB
how do ya get the airbag off and got any tips on getting the cyylinder out
DSMMH
Jul 2, 2012 07:45 AM
ironmine
Oct 22, 2009 11:53 AM
CJay
Oct 11, 2007 10:28 PM
WOLFBAYOU
Dec 18, 2002 05:57 AM
