space between valves and piston
Old May 23, 2007 | 10:30 AM
amish77's Avatar
amish77
I was wondering how much clearance there is between the vlaves and piston in a Ford 300 I6. I'm in the middle of a full performance rebuild and want to know how much the machinist can remove from the deck of the block and the head when he's straigntening them out. I'm planning on using Clifford Performances' oversized valves that measure at 1.940'' intake and 1.6'' exhaust. I'll also be using their piston heads if that matters. Thanks for any replies.
Old May 24, 2007 | 10:42 AM
slammercb's Avatar
slammercb
Minimums should be .100 on exhaust and .080 on intake. Usually you are safe with taking .020 from deck and .030 from heads. Be sure to do a p/v clearance test using a light spring on a couple of cylinders. You can pick up additional clearance if needed by using a thicker head gasket.
Chuck
Old May 24, 2007 | 06:29 PM
amish77's Avatar
amish77
thanks slammercb. I'll tell the machinist where my maximums are. I was thinking that If I stayed away from the thicker head gasket that I might get a little higher compression. Figured it was worth a shot. the spring test sounds like a great idea, but where would I get the low load springs?
Old May 24, 2007 | 09:44 PM
slammercb's Avatar
slammercb
Most hardware stores carry an assortment of coiled springs. Doesn't have to exact size, just approximate height. You just need something to keep tension on the rocker arm.
You probably won't need a thicker head gasket. More of a suggestion if your p/v clearance becomes an issue.
Chuck
7.3 PStroke
46
Aug 9, 2016 07:48 AM
saleen065
Aug 11, 2008 10:06 PM
MintFord
31
Oct 26, 2007 06:47 PM
rsalter66
May 28, 2007 01:35 PM
brown 4x4
25
Feb 13, 2005 07:34 PM
