390 Done
Old May 24, 2007 | 06:50 PM
rusty70f100's Avatar
rusty70f100
If the valve is sticking part way open that could do it too. I was only thinking back to when I had my 390 heads done. They put in the hardened exhaust valve seats, but they were all over the place in terms of height! I can safely say a non-adjustable valvetrain would have been a disaster with those heads like that.
Also, IIRC the FE requires a bit more valve to guide clearance than other motors. Perhaps the shop where the heads were done left 'em a bit too tight and that is causing sticking? Maybe also causing a bent pushrod? I had this happen too...
Old May 24, 2007 | 06:54 PM
Redmanbob's Avatar
Redmanbob
Just for _-_-_ 's and giggles lay a straight edge across the valves tips with the rocker assembly off if you find yourself in a position to do so.. Are all the tips at least close in height ? If that one is way low tap the valve tip with a hammer (be careful-wear goggles) and see it it frees it.
Old May 29, 2007 | 09:57 AM
highboy390fe's Avatar
highboy390fe
well i was away all weekend and will be tearing into the truck tonight to see what is going on. I was also looking at the adjustable rocker arms setups and was wondering do i have to get all new everthing or can i just install adjustable rockers onto my old shafts. Thanks
Old May 29, 2007 | 02:53 PM
rusty70f100
You need the adjustable rocker arms, matching pushrods, and the 3 finger oil baffles.
Old May 29, 2007 | 03:14 PM
highboy390fe
where is the cheapest place to get these at? I didnt exactly have these in the big budget but need them now i guess.
Old May 30, 2007 | 01:27 AM
brandon75_390's Avatar
brandon75_390
also try a compression test to see if the valve is fully seated or stuck open!
Brandon
Old May 30, 2007 | 07:30 AM
highboy390fe
yes i will be trying that.
