Vibration from Stop
Old May 23, 2007 | 05:56 AM
Madmaxz's Avatar
Madmaxz
Vibration from Stop
I test drove an 02 f250 w/ 108k miles yesterday at take off there was a bad vibration when giving it gas from a stop. but after 30-40 mph it would go away. ive test drove 5-6 trucks in the last week this one feels like its down power too on the lowend takeoff almost like a miss but its not missing.. tranny slipping? TQ converter not locking up? after 40-50mph it pulls hard..
Old May 23, 2007 | 06:38 AM
skittlejr's Avatar
skittlejr
if you check in the 99-03 powerstroke or the heavy/super duty forum they would be able to help you better on this one. double check the name of this forum. if there is no vibration during idle i would get the whole drive line checked out. get under it and start shaking stuff around and see what ya find.
Old May 23, 2007 | 09:17 AM
Neal 97 250's Avatar
Neal 97 250
May be a U joint but I doubt it since it doesn't vibrate while driving but worth checking. May also be trans problems. Other than that chec with the other forum they may know something I don't.
Old May 23, 2007 | 10:03 AM
tjbeggs's Avatar
tjbeggs
could also be a bad midship bearing. also many SD need to have the midship bearing shimmed down to get rid of a vibration that is common.
Old May 23, 2007 | 10:14 AM
Neal 97 250
Is the midship bearing the one half way down the driveshaft? If so good call Tim.
Old May 23, 2007 | 10:36 AM
tjbeggs's Avatar
tjbeggs
yes the midship bearing also called the carrier bearing is the bearing in the middle of long wheel base trucks.
Old May 23, 2007 | 10:41 AM
Neal 97 250
Carrier bearing... That is what I am used to hearing. Thanx for the clarification.
Old May 23, 2007 | 12:53 PM
miker67's Avatar
miker67
Is the truck lifted? If it is, then I would definately look into shimming the carrier bearing. Rule of thumb is 1/4 inch shim for every 1" of lift. It doesn't have to be a full blown suspension lift either. I did an add a leaf helper spring for a guy one time that lifted his rear end almost 4 inches empty. Any more than 2 inches above stock is enough to throw the rear end out of whack.
If the truck is not lifted, I would check the u-joints, then the carrier, and if that doesn't reveal anything, look closely for abnormal tire wear. If a tire is off balance, it can cause wierd vibrations, check for missing wheel weights and what not.
Old May 24, 2007 | 05:29 AM
Madmaxz's Avatar
Madmaxz
it was the u joints
