Sponsored by: Real Truck
Wheel Swap
Old May 22, 2007 | 08:53 PM
Bagmanners's Avatar
Bagmanners
Question Wheel Swap
Has anyone tried installing a set of the post 2005 - 18 or 20 inch on a 2004 or earlier Super Duty? I've heard that it will work, but that wheel spacers may be required. Just trying to confirm & perhaps get a heads up to any potential issues. Thanks in advance!
Old May 22, 2007 | 09:40 PM
roughrider46's Avatar
roughrider46
thought they changed lug pattern on the 05's, mines a 03 with 8-170 was told they where different.
Old May 22, 2007 | 09:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
From what I understand, the bolt pattern is the same but the offset is different to clear the revised front suspension.
Old May 22, 2007 | 09:49 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Like redford said, the bolt pattern is the same but the backspacing is different, by more than a inch. '05-up wheels will sit inboard more than a inch from the stock when installed on a pre-'05. They kind of give you the railroad truck look and they do rub the leaf springs. Yes, you can use wheel spacers but it is not a recommended practice.
If you are looking for larger factory wheels for a pre-'05, the best choice is a set of factory 18"s off a '04.
Old May 22, 2007 | 09:55 PM
Storm's Avatar
Storm
My buddy who owns Discount Tire in Gtown pulled up the SD and he found 8x170 and 8x6.5.. Dont know if 8x6.5 is the Gas SD or not.. So there are two bolt patterns... Not sure why lol.. Mines 8x170
Old May 22, 2007 | 10:26 PM
PowerStrokeHD
All '99-up SRW SD's are 8x170, gas or diesel does not matter. I believe there was a bolt pattern change in the mid to late 90's to 8x170, but im not sure what year this happened off hand.
Old May 22, 2007 | 10:50 PM
Mud Doc's Avatar
Mud Doc
The 170 is mm for the bolt center spacing; the 6.5 is inches for before they went to metric? 8boltx170mm; 8boltx6.5inches?
Old May 23, 2007 | 12:07 AM
RACERX7775's Avatar
RACERX7775
the new sd trucks and excursions all have 8x170 mm.. there was a change on the thread pich on the studs on the 99-2000 trucks??pre sd trucks, they were all 8x6 1/2.
Old May 23, 2007 | 06:41 AM
HeavyAssault's Avatar
HeavyAssault
For the lugs 99-03(?) they were 14mmX2.0 then 04-current they are 14mmX1.5. Bolt pattern has been addressed in other posts.
Old May 23, 2007 | 08:03 AM
redford's Avatar
redford
170 millimeters is 6.69291 inches, or 6.7 inches. There are not two bolt patterns. 8x170mm and 8x6.5 inches are the same pattern.
Old May 23, 2007 | 09:14 AM
redford's Avatar
redford
Screwed that up....what I meant to say was I think the 8x6.5 was used on earlier trucks.....not that 6.5 and 6.7 are the same.
I need more coffee.
Old May 23, 2007 | 09:41 AM
bczolone's Avatar
bczolone
I had 18" wheels from a 2006 on my 2004. The offset is the problem due to coils. The 17" 2005 and later wheels will NOT work because of diameter, however the 18" will with very slight rubbing at full turn with stock size tires. You can get spacers to remedy this if it bugs you, but I don't know if you have to install longer studs. I personally did not like it but it was only for a few days while they ordered the tires i wanted, the dealer had stacks of take-offs.
zombiefied 247
Nov 29, 2013 08:03 PM
xjcamaro89
2004 - 2008 F150
27
May 16, 2009 10:29 PM
boomerang
1997 - 2003 F150
May 16, 2009 02:57 PM
riot
Mar 22, 2007 12:00 PM
66sprintw53
Nov 16, 2004 09:45 AM
