Biggest tires
Old May 22, 2007 | 08:48 PM
MrRogers's Avatar
MrRogers
Biggest tires
What are the biggest tires I could put on my '90 302 F-150 2wd with all suspension stock? I've got 33's on there right now. I have an incredible turn radius and no rubbing at all but was wondering if, down the road, i could put bigger ones on there. Also, what sort of lift would i need for 35" if they won't fit stock?
Thanks,
Josh
Old May 22, 2007 | 09:58 PM
Idiot730's Avatar
Idiot730
its a 2wd dont waste the time just stick with the 33's if they look good
Old May 22, 2007 | 10:29 PM
alstieg's Avatar
alstieg
With no lift 35's won't fit. My 33's didn't fit on stock until I put bumper spacers on. I have a 4" lift on a '95 4x4 and 33 12.50's clear. either tire , the 5.0 will have a hard time driving them unless you change your gears.
Old May 23, 2007 | 12:22 PM
rattosh51's Avatar
rattosh51
Also, I was told by a local tire company here that when you add bigger tires, your
computer has to be reprogrammed to tell it the new size. Hadn't heard of that before, but that's what they said.
Old May 23, 2007 | 12:40 PM
andym's Avatar
andym
That depends on the year of the truck. 92 & newer, yes. Older, no.
Old May 23, 2007 | 01:06 PM
rattosh51's Avatar
rattosh51
Ahh, yes this was talking about my '94...thanks Andym
Old May 23, 2007 | 04:32 PM
alstieg's Avatar
alstieg
I have a '95 and I don't think its new enough to be reprogrammed for bigger tires. I think its for like 99 and newer unless i'm wrong. If its possible, I'd like to do it because i'm running 33 12.50 mt's
Old May 23, 2007 | 07:08 PM
andym's Avatar
andym
I said 92 & newer and I meant it.
Seriously... in 1992, Ford started using a PSOM to control the speedometer. There is a tech article here on how to re-program it for larger tires.
92 & newer... I promise.
Old May 23, 2007 | 07:36 PM
MrRogers's Avatar
MrRogers
well....shoot. What if i went with larger ones in the rear. To give it an aggressive stance? I'm trying to "hot rod" my truck.
Alnotch
6.4L Power Stroke Diesel
Jan 3, 2015 10:56 PM
GeneralC.
Apr 10, 2007 08:30 PM
onekwik12
Jan 15, 2005 03:05 PM
broncopimpservice
Bronco II
Apr 8, 2002 08:08 PM
