302 h.o ?
Old May 23, 2007 | 10:38 PM
Conanski's Avatar
Conanski
Originally Posted by flareside_thunder
According to my chiltons...my 67 289 has the same exact firing order as my 95 flareside 13726548 so then what is my 95?
It's a truck engine. The cam is close to a HO cam, but with less duraton. It also has lower compression cast pistons compared to the 9:1 forged slugs in the good HO.
Old May 28, 2007 | 10:32 AM
PierceEye's Avatar
PierceEye
Originally Posted by eatfish
Can't he just look at the firing order? The HO should have the 351W order, non HO will have the regular 302 order.
All 302 HO motors run the 351 firing order
Old May 28, 2007 | 12:10 PM
RacinNdrummin's Avatar
RacinNdrummin
Truck engines were also 9:1. As far as HO being cast into the intake, are you sure that was in all the HO engines? I was under the assumption that all the upper intakes after 87 (E7SE) were all the same, so why would they have HO cast into it?
Old May 28, 2007 | 02:57 PM
Conanski's Avatar
Conanski
All the data I have seen says the trucks are 8.5:1. I have a set of factory pistons out of my 5.8 that are dished. The flattops in it now just give it 9:1 CR.
The runners in the HO intakes are slightly bigger than the plane 5.0 intake.
Old May 28, 2007 | 03:22 PM
flareside_thunder's Avatar
flareside_thunder
I beg to differ.The specs for my 95 F-150 says that it has 9:1 compression.Hmmmmm,that's with E7TE heads.
Old May 28, 2007 | 03:29 PM
RacinNdrummin
I know the runners are both longer and bigger on the E7 manifolds over the E6 manifolds. But I thought that all the E7 manifolds were the same, Ill have to verify next time im out at the JY. As far as telling if its an HO or not, there is easier ways than removing the plate on top. If it has a 60mm TB, its the HO, also if it has yellow top injectors and a car style intake (and the engine hasnt been molested) its the HO.
Old May 28, 2007 | 05:56 PM
flareside_thunder
Speaking of injectors.......what poundage are the orange tops?
Old May 28, 2007 | 06:43 PM
RacinNdrummin
19lbs is the rating for the yellow/orange tops
Old May 28, 2007 | 09:10 PM
baddad457's Avatar
baddad457
Your chiltons book is wrong. The "base" 5.0 found in Crown Vics will have E6SE heads, easily identified by a large "S" cast into the lower front corner of the passenger side head, next to the valve cover (same location but reversed on the driver's side head) The water pump is a std rotation, and the accessory drive is a two belt serpentine system. It will be a roller motor though and a good candidate for a buildup when replacing the heads, pistons and intake.
Old May 28, 2007 | 09:15 PM
baddad457's Avatar
baddad457
Conanski's right on about the HO being cast into the upper intake. This was reseached by some members on the Ranger Power Sports V8 forum a couple years ago. The uppers look similar, but are different internally.
Old May 28, 2007 | 11:00 PM
LxMan1's Avatar
LxMan1
The 289 and non HO 302 have the same firing order. The HO uses a 351W firing order.
Old Jun 1, 2007 | 11:37 AM
dragogt's Avatar
dragogt
any 87-92 mustang gt will have the HO engine 225 hp + 300+ tq
Old Jun 1, 2007 | 11:45 AM
  #28
rsalter66's Avatar
rsalter66
t-birds also had an h,o , if i understand you correctly the motor came out of a crown vic? chances are that it is not a h,o , can't he look up the number's on the block??
Old Jun 1, 2007 | 07:19 PM
  #29
baddad457's Avatar
baddad457
They all used the same blocks, from the base 5.0 to the HO and GT40 5.0. They also shared the same cranks, rods, lifters, rockers,etc plus a few other parts I can't think of right off hand. The cam, upper/lower intake, pistons and exhaust headers were the parts that set the H.O. apart from the rest.
Old Jun 5, 2007 | 11:08 PM
  #30
joewaldner's Avatar
joewaldner
all it says is 5.0L efi on the badge, and if it wont work in my f350 I could just put it in the 86 f150, which had a 302 in it .... right .... 91 crown vic engine in a 86 truck ?
